Touran rear seats conversion
Seanick
Post by Seanick » Sat May 18, 2019 10:54 am
Good morning guys,
Can anyone point me in the right direction please I’ve tried searching for some info on how best to trim the interior side door step after installing the rear seat conversion, or is it just measure the gap and have a go🤣🙈🤣... I’m assuming caddy’s with the seats already in have trim that is already suitable? Any part no?
Seanick
robblowen
Re: Touran rear seats conversion
Post by robblowen » Sat May 18, 2019 9:38 pm
@seanick do you mean where the long flat step used to be before you took the false floor out? If so you want the kombi step, I paid about £16 from VW for my maxi. Number 4 on the pic but double check the part number when you phone them, I don't know what type of caddy you've got but that fits the maxi, theres one for each side.ImageImage
Post by Doc » Sat May 18, 2019 9:56 pm
There is no original trim to fit a Touran second row in a caddy, no matter what you buy will require modification.
The part given above is a good place to start but having the Touran trim to go with it works well.
Seanick
Post by Seanick » Sun May 19, 2019 9:31 am
Hi guys,
@robblowen Yes that’s exactly what I mean... I’ve cut the existing trim but obviously it doesn’t flow down towards the carpet as I’d like... mine is a swb so the part may be different from yours but thank you for your time posting the part no.
@doc When you say the touran trim?... do you mean the part that fits over the side/top of the front metalwork for the seats?
Seanick
Post by Doc » Sun May 19, 2019 9:54 am
The Touran has a plastic trim section that covers the side step and the corner of the seat mountings, if you've fitted Touran seats you need that part and then hack it up to match the caddy. Essentially, you've got two different parts from two different cars so you need to make a hybrid of both pieces.
Mark.w
Post by Mark.w » Mon May 20, 2019 1:49 pm
Hello,
I am interested in this too, do you have any photos of the project?
Seanick
Post by Seanick » Mon May 27, 2019 7:27 pm
Hello,
Hi
I do m8 but I'm away for work atm... will post one when I return 👌
Seanick
Post by Seanick » Mon May 27, 2019 7:31 pm
The part no4 that you got is that the drivers side?... my door is on the passenger side...so would i be looking at part no 2?..
robblowen
Post by robblowen » Mon May 27, 2019 8:02 pm
@Seanick it's still part number 4 heres the description part of it, if you look there is 4 and (4) ones left the other right. I ordered them for my maxi and they fit, double check with your reg/vin number when you ring to order, one of them was on back order so you have to pay up front and its none refundable if it's wrong. Hope that helps mate.ImageImage
Seanick
Post by Seanick » Thu May 30, 2019 2:46 pm
That’s brilliant m8.... sorry never loooked at parts list only the exploded diagrams 🙈... cool I’ll get on it as I think it’ll make a huge difference 👍
Seanick
robblowen
Post by robblowen » Thu May 30, 2019 2:51 pm
No worries dude, hope you get it sorted.
chrisd317
Post by chrisd317 » Sat Jun 08, 2019 3:35 pm
does anybody know if there's a part that goes on the bottom of the seats in between the seat and the carpet at the front?
