Ok,
So eventually I have found a asz pd130 engine for the caddy conversion 20miles from me.
Its advertised as ASZ pd130 highline VW bora.
Am I correct in thinking the highline is only the spec of the model nothing to do with engine ?
Go easy
Re: Go easy
Yes you are correct I believe highline is just spec inside cockpit
- Novakid
Re: Go easy
Thanks for that would have been to late as i have agreed to buy already.
Also heads up to any interest I will have manifold turbo and injectors from the pd130 coming up fir sake soon as I am going to run BLS.
Re: Go easy
You not swapping them over then
- Novakid
Re: Go easy
Putting the the asz engine but running all bls
ancillaries.
Its already mapped to 140 so would not gain anything and no intention of wanting more power.
ancillaries.
