Turbo where best and which are best
In need off a turbo off a bls engine which one is best and where to get one from the garage has said the diaphragm in the actuator has got a split in it and has basically said I need a new turbo because off this is can you just replace the actuator off turbo cheers Gordon
Re: Turbo where best and which are best
Yes you can just replace the actuator providing your turbo is alright, however I think they need to be set up properly. Darkside do one for 40 quid. Still a lot cheaper then another turbo..
Thank you, what would tell tell signs off a turbo gone because there is no smoke or anything and when it not limp mode boost amazing
