Opening the rear door from the inside?!?
Madmax245
Post by Madmax245 » Fri Jun 07, 2019 2:08 pm
So my caddy is set up as a camper and it it getting really annoying having to go round the side to open the rear doors. I vaguely remember seeing a kit somewhere that was basically a retro fitted internal handle. Does anyone know where I can get one from because I don’t seem to be able to find anything about them.
Beers, Burgers, Bikes
robblowen
Re: Opening the rear door from the inside?!?
Post by robblowen » Fri Jun 07, 2019 2:18 pm
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Original post here mate
Madmax245
Post by Madmax245 » Fri Jun 07, 2019 2:19 pm
Nice one cheers
robblowen
Post by robblowen » Fri Jun 07, 2019 2:19 pm
@madmax245 not sure if that link worked if not, it's in the how section of the forum.
parsons668
Post by parsons668 » Fri Jun 07, 2019 8:36 pm
its cheaper to buy direct from VW themselves surprisingly, part numbers below
a2k0 829 309 a9b9 (lever)
a2k0 827 699 a (Trim)
a2k0 829 323 (Pull rod)
AN 909 400 01 (bolt) x3
A7h0 827 947 (Clip)
or if you dont want to talk to anyone haha ebay sells them for £65, just wack the item number in 323408820649
SnoWhite
Post by SnoWhite » Tue Jun 11, 2019 7:03 am
Is there an equivalent available for the Tailgate rear door Caddy?
My Maxi sometimes doubles up as a camper - but getting out via the rear door would be so much easier than via the sliding door.
PhilipO
Post by PhilipO » Wed Jun 12, 2019 8:45 pm
A mate have the tailgate door on his camper caddy, he just wired up a string from the standard mechanism, pulling straight back. Nothing fancy, so it should not be too hard, but it is not pretty. ;)
MrKire
Post by MrKire » Thu Jun 13, 2019 10:20 am
A7h0 827 947 (Clip)
Great info.
Just went to the dealer up here in Sandviken and the whole Kit was Sek 500 when using the list of parts listed. (500 sek eq GBP 42.-) :D
Thanks!
markvw89
Post by markvw89 » Sat Jun 15, 2019 6:05 pm
Might have too do this to mine 👌
jackmarshall
Post by jackmarshall » Thu Jun 20, 2019 11:18 pm
Cheaper option is to drill a hole in the ply lining big enough to get your thumb through just above the lever in the lock mechanism. Works a treat
parsons668
Post by parsons668 » Fri Jun 21, 2019 12:58 pm
Fitted my rear handle yesterday, took literally no more than 2 minutes to fit. Hardest bit was cutting the ply in the right place and fitting the trim to make it look nice.
Sent from my VOG-L09 using Tapatalk
