Rad fans
Rad fans
Hello I’ve noticed my rad fans on my 2.0 cr 140 are on even when the engines not up to full temp,and sometimes stay on for a few seconds when I turn it of.
Everything seams fine,gets up to temp fine etc.is it an issue?
Re: Rad fans
This is usually a sign that the outside air temperature sensor, located in the lower front grille, is faulty or disconnected.
Re: Rad fans
Oh ok,I’ve just noticed a potential problem that may effect it also,
It takes a while to get to 90deg and even then it dips below often I’m talking a 20 mile drive till it stays at 90,is that thermostat?
Re: Rad fans
I'd say taking a long time to warm up is more than likely because the fans are running and cooling the engine down.
Re: Rad fans
Wouldent the outside air temp senser bring a fault code up thought,I’m not initially sure they run all the time but on quite a few occasions they do,
It’s always taken ages to get to temp and always dips below until you go on a long run then it seams to stabilise
I’ve only had it a month or so
Re: Rad fans
Is the outside temperature showing on your instrument cluster?
Do you have VCDS to check engine temperature?
Re: Rad fans
No it isn’t showing,it did at first then when it got low on fuel it changed to mile to empty and no won’t swop back.
I don’t no
I don’t no
Re: Rad fans
So, you've checked the outside temp sensor it still there and connected?
Re: Rad fans
I haven’t but I will do tomorow
Re: Rad fans
How do the front grills come out,as wanting to paint them anyway
Re: Rad fans
You need to take the bumper off to release from the back.
