So stripping my bls an swapping over parts to asz.
First issues not sure what it's called but....
The bls seems to have an extra port as seen in the photo this comes from the bottom of the oil filter and into the block (think its water pipe)
Problem is where do I put the hose if i have nothing to attach it to.
Issue #1 bls/asz
- Novakid
Re: Issue #1 bls/asz
Issue resolved
What was the fix?
You shouldn't need to worry just use the oil filter housing on the as
- Novakid
Yup like he says just use the asz one .Wrcpulsar wrote:You shouldn't need to worry just use the oil filter housing on the as
I got way in depth over thinking this conversion and it's very straight forward and I am not a mechanic
