1T0920972A do you know if this will fit 06 caddy
As about guys touran high line clocks are theses easy to get coded cheers Gordon
Re: 1T0920972A do you know if this will fit 06 caddy
They are pretty straight forward if you have the right equipment to do it as the immo will need to be taken from the original cluster and transferred into the new cluster.
So will this part number fit and can they be coded via vcds
Yes, they will fit your van. VCDS won;t be able to code them though, u need special tool to do IMMO. When new clocks are fitted in make sure u also know the head unit PIN as otherwise your radio won't work anymore (if still OEM one). If local i can code them for u
I have genuine VCDS, VagCAN Pro, SMOK and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
Where abouts are you mate
- Caddyluv
He is in Hemel Hempstead done quite a few of my bits.
Why is every one miles away or do I live in the back end off no where lol
- Caddyluv
There must be someone on here that’s close. Where are you.
I am in skegness Lincolnshire mate
- Caddyluv
Yeah you live in the middle of nowhere. uuuummm. I think Claudiu would do it by post. 1 min I will give him a nudge. I think he will need your key. 1 min.
- Caddyluv
Yes mate. You can send it. But he will need your key. Pm him.
Hey mate, i can offer postal service if u want. I need your original cluster and a key to copy immo data from it and then write it in the donor cluster.
What's cost would this be a plug and play then mate
After i copy immo data from original cluster will be plug and play. Only issue will be head unit PIN if u don’t have it
Right I got stero pin if you want to send me price on pm
