Irratic idle when cold goes when warm any ideas
gjseb
Post by gjseb » Sun Jul 07, 2019 7:51 pm
As above guys tried doing a bit off research can't seem to bring anything up
dipstr
Re: Irratic idle when cold goes when warm any ideas
Post by dipstr » Sun Jul 07, 2019 10:07 pm
Carry out injector leak off test
gjseb
Post by gjseb » Mon Jul 08, 2019 7:10 pm
Is that done via Vcds mate
gjseb
Post by gjseb » Mon Jul 08, 2019 8:15 pm
gjseb
Post by gjseb » Mon Jul 08, 2019 8:16 pm
There's injectors test looks fine too me
Boonalon
Post by Boonalon » Mon Jul 08, 2019 9:01 pm
There is a micro quantity calibration that can help with symptoms like you have at times but you need ODIS, I did a golf last week with same complaint
dipstr
Post by dipstr » Mon Jul 08, 2019 9:18 pm
No mate you will need to take to garage. Basically you remove the leak off pipes from injectors then fit separate pipes to injectors. Start engine and see which injector is giving a lot of return fuel over a period of about 30 secs. Whichever one(s) give off a lot of fuel needs replacing
gjseb
Post by gjseb » Tue Jul 09, 2019 9:01 pm
Right so need to get to garage then
