Asz engine transplant
gjseb
Post by gjseb » Wed Jul 10, 2019 7:40 pm
Right guys I and just go process off trying to get things together for transplant I am looking at engine from Srs which has had the crank seal swapped been done already, but I am trying to merge this with a auto gear box will this engine be fine or do I need to look for one off an auto. Also will every thing off my bls bolt on to this engine as they are saying it's plug and play
Cheers Gordon
Novakid
Re: Asz engine transplant
Post by Novakid » Thu Jul 11, 2019 5:48 pm
Egr cooler wont bolt on as no holes for it on the asz block. Either make a plate or get the delete kit. Sure darkside developments sell one.
Picture of it attached to bls block
gjseb
Post by gjseb » Thu Jul 11, 2019 7:31 pm
Right spot will this need to be mapped out or just deleted or do I just make a bracket to hold it in place mate
Novakid
Post by Novakid » Thu Jul 11, 2019 8:52 pm
If removed a light will come on ( run fine ) believe it's about £70 to make it out the system the u need to modify the water line also if u remove it.
I am personally making a bracket just to keep it like for like. Can always remove at a later date when I have the money for map.
gjseb
Post by gjseb » Thu Jul 11, 2019 9:03 pm
This might sound bad but could you send me pic or drawing off bracket so I can have a look and where you going to attach it too you going to run the bls injectors and turbo or you running pd130 injectors and turbo will these run on original wire and that
Novakid
Post by Novakid » Thu Jul 11, 2019 10:02 pm
I have not made this bracket yet. But when u look at the block u will see 3 larger holes that are not In use. I am put a plate on with them and attaching the cooler to it.
Yeah I have put bls turbo and Injectors over already.
Novakid
Post by Novakid » Thu Jul 11, 2019 10:08 pm
This 3Image
gjseb
Post by gjseb » Thu Jul 11, 2019 10:10 pm
Spot on mate going to start my own next week so just getting as much info as possible mate, once parts are swapped over and crank sensor sorted is just all plug and play mate
Novakid
Post by Novakid » Thu Jul 11, 2019 11:12 pm
Not that far on yet mate.
But it should be plug and play.
I only have the crank seal to fit and new timming belt and it's time to fit it.
gjseb
Post by gjseb » Fri Jul 12, 2019 7:29 am
Have you done the modification for sensor yet where crank seal goes in
Novakid
Post by Novakid » Fri Jul 12, 2019 7:51 am
Yeah all done mate. Image
gjseb
Post by gjseb » Fri Jul 12, 2019 11:31 am
Sorry for all questions, did you put new Bls seal in and is hard to do, also now that mod been done it should all basically just plug in and fire up with same clocks and everything is that correct
gjseb
Post by gjseb » Fri Jul 12, 2019 11:36 am
Also you say that you using your bls injectors and your turbo what if you was to use asz injectors and turbo would it still be plug and play as you won't gain any power from using your standard turbo and injectors will you
gjseb
Post by gjseb » Fri Jul 12, 2019 11:43 am
Also you running your caddy inter cooler
Novakid
Post by Novakid » Fri Jul 12, 2019 12:08 pm
Before I started this conversion I googled and researched every page out there and the questions u are asking have been covered 100 times..
I am running all my bls parts only difference is asz block.
U will need a re map if keeping asz turbo and Injectors.
