Reverse camera RNS315DAB
Avalanche
Post by Avalanche » Sat Aug 03, 2019 1:48 pm
Has any fitted a reverse camera to the RNS315DAB?
Thanks, Jason
2011 Silver 1.6tdi Maxi Panel Van
Eddie-NL
Re: Reverse camera RNS315DAB
Post by Eddie-NL » Sat Aug 03, 2019 2:15 pm
I've fitted one
You need an RGB Type camera
I used one like this
https://www.carsystems.eu/vw-scirocco-1 ... d1482.html
I bought a Tiguan handle camera and cut the camera out (was cheaper)
then just used
https://www.carsystems.eu/vw-tiguan-5n0 ... d1631.html
Avalanche
Post by Avalanche » Sat Aug 03, 2019 2:31 pm
Thanks Eddie, expensive new, I shall keep my eye out for a 2nd hand one too.
Beaker2135
Post by Beaker2135 » Sun Aug 04, 2019 9:54 pm
Similar to Eddie I used this kit
https://www.carsystems.eu/vw-caddy-2k0- ... d1159.html
I had the new handle colour coded before I fitted it
Eddie-NL
Post by Eddie-NL » Sun Aug 04, 2019 10:05 pm
I think they cut the hole, part number they have listed is just the same as the one fitted
Beaker2135
Post by Beaker2135 » Mon Aug 05, 2019 7:39 am
Yeah that’s right, Eddie
tommyzooom
Post by tommyzooom » Mon Aug 05, 2019 2:27 pm
So can this be fitted to all the RCD 315's then?
Beaker2135
Post by Beaker2135 » Mon Aug 05, 2019 8:39 pm
You should be able to if it has a 26 pin connector on the back
tommyzooom
Post by tommyzooom » Fri Aug 09, 2019 8:55 pm
It does :D
How does this work in conjunction with factory reverse sensors?
Does it override them? work in combination with them?
Eddie-NL
Post by Eddie-NL » Fri Aug 09, 2019 9:40 pm
It does :D
you need to code the parking module so that you get ops show on the left side of the screen
Beaker2135
Post by Beaker2135 » Fri Aug 09, 2019 9:45 pm
Yeah they work together
If you have parking sensors fitted you'll also need to go to
10-Park/Steer Assist click coding: long code helper: and check the box for rear view camera installed
Byte 0 Bit 5
tommyzooom
Post by tommyzooom » Fri Aug 09, 2019 10:00 pm
Thank you both.
Now to find a reasonably priced camera
