2l engine issue
hungry monkey
2l engine issue
Post by hungry monkey » Sun Aug 04, 2019 9:40 pm
Hey all
Got my van booked into the garage Tuesday, as i've an oil leak coming from the engine - nothing too serious, but a few spots on the driveway, so wanted to get it nipped in the bud. Guy at the garage had a quick look a few days ago and said no issues driving it - probably a gasket or something.
Anyway
Drove it a couple days ago, and heard a sudden 'psssht' noise with a little jolt - thought i had a sudden puncture, but tyres all good - felt like I'd driven over a can of coke or something... have no noticeable loss of power, but under engine braking there's a faint whistle sound. Not driven it since i got home after that.
Mate at work suggested a boost pipe or something having popped off, but wondering whether any of you lot have had this?
just ticked over 100k miles, it's a 2l 140bhp 2011 plate maxi kombi.
Bionicman
Re: 2l engine issue
Post by Bionicman » Sun Aug 04, 2019 10:03 pm
It could be a intercooler hose split, loose on a connection or totally come off. The oil spots could be relevant to that problem also as the intercooler hoses/pipes will have a little bit of oil in them from the crankcase breather. Hope its a cheap fix anyway mate for you.
hungry monkey
Re: 2l engine issue
Post by hungry monkey » Mon Aug 05, 2019 9:14 am
Thanks mate - fingers crossed it won't be a big bill - got a mk1 needing a load of work too, and my coffee machine just died - expensive month :roll:
hungry monkey
Re: 2l engine issue
Post by hungry monkey » Tue Aug 06, 2019 10:31 am
Well, turns out something in the box disintegrated taking the housing with it. New box time.
Bionicman
Re: 2l engine issue
Post by Bionicman » Tue Aug 06, 2019 11:35 am
What a bas***d. Thought it would be a easy fix.
hungry monkey
Re: 2l engine issue
Post by hungry monkey » Tue Aug 06, 2019 2:53 pm
Yeah me too... £2800 all in apparently
SnoWhite
Re: 2l engine issue
Post by SnoWhite » Tue Aug 06, 2019 3:49 pm
£2,800 - Ouch
I would be tempted to make a few calls for alternative quotes before committing to that quote!
As its a 2.0 I assume its a 6 speed manual? If so you might want to search on line for replacement gearboxes. At the moment on eBay there is a 6 speed for well under £400 after delivery is factored in.
I cannot but think there is bound to be a garage out there able to swap out the damaged gearbox for under £2,400.
Is that is a main dealer quote?
Then you might want to get a quote from an independent VW specialist garage - like Simon at Central VW/Audi in Ellesmere Port - even if you do not take the car to them for repair they know caddy's very well and can usually give you a fair quote - their hourly rate is a fair bit lower than dealers.
It may be worth checking your insurance/credit cards just in case they offer breakdown cover as I assume the Caddy will now need to be recovered to whoever is going to fix it and that can be a quite costly extra.
hungry monkey
Re: 2l engine issue
Post by hungry monkey » Tue Aug 06, 2019 9:45 pm
Thanks mate. TBH I've no idea how good a deal it is. Mates were suggesting a £4k bill wouldn't be off, so £2800 sounded reasonable. The quote is as follows;
£1300 + VAT for the gearbox (refurbished, with a 12 month warranty, from Gloucester Road Gearboxes in Bristol)
£250 + VAT for the casing
(total £1860 inc VAT)
5 hours labour (£330)
Clutch £156 (inc VAT)
Flywheel £288 (inc VAT)
Slave cylinder £48 (inc VAT)
Total £2882
The garage are a VW specialist, have been V good in the past too. They've suggested I look for a 'box also, but their quick look didn't come up with much - it's a LWR code box.
My other query is that the clutch and flywheel sound rather cheap to me!
I'd rather get the parts from a place I trust, but I also don't want to get stung - I'm gonna have a look around anyway!
