1 week in.... mods so far
c_j
Post by c_j » Mon Aug 05, 2019 7:26 pm
Hi all, so I picked it up last weekend looking like this
Got to work straight away and stripped out
Sound matted, sides floor and roof. God that was a boring job!
Then insulated.
Then I moved onto carpeting.
Next was LED Drl’s and head lights
Also added rubber floor mat, racking and some secure tool storage
Led strip lighting for the roof and made a wireless charging mat for the slot bellow the head unit
Final addition are some new wheels
And that takes me upto this weekend, quite please with what I’ve got done last week
Let me know your thoughts and ideas. I’ve got more ideas in the pipeline
gjseb
Re: 1 week in.... mods so far
Post by gjseb » Mon Aug 05, 2019 11:48 pm
Looks good mate, what did you use to make wireless charging pad mate
Skully
Post by Skully » Tue Aug 06, 2019 7:21 am
Looking good.
I have the same wheels on my Caddy.
1996 Mk3 VR6
2017 Caddy Maxi 2.0 TDI
2013 RSV4 track bike
c_j
Post by c_j » Tue Aug 06, 2019 7:34 pm
Thanks Gjseb
I got a std wireless chargers from amazon like this
And then just took it apart and mounted the internals to the underside of the tray under the head unit.
Once id made that part I just got the power via a 12v USB adapter like this and connected under the tray as there is a large void.
Cheers cj
c_j
Post by c_j » Tue Aug 06, 2019 7:37 pm
Thanks skully, ye I tried a few different styles but kept coming back to these. I think they suit the silver really well.
craig.head
Post by craig.head » Thu Aug 08, 2019 8:49 am
love your attention to detail on the load area, it looks better than the boot of some cars.
ShaneM
Post by ShaneM » Thu Aug 08, 2019 12:17 pm
Did you notice a difference to road noise etc after the insulation or was it more just to keep heat in?
c_j
Post by c_j » Thu Aug 08, 2019 7:07 pm
Thanks Craig.
Nice to hear that, I do allways try and turn out a nice job.
Cj
c_j
Post by c_j » Thu Aug 08, 2019 7:12 pm
Hi Shane, I’m hoping it gives the benefit of keeping the warmth in in the winter and help keep it cooler in the summer but predominantly for noice reduction.
I can’t comment purely on the insulation as I did the dodo matting and the insulation at the same time but can say the pair together made a brilliant improvement to the road noice and drumming noice that come from the rear. Very quiet after.
Cheers cj
alfieargyle
Post by alfieargyle » Thu Aug 08, 2019 7:55 pm
Looking good mate. Have you powered the new led roof lights from the original centre light, or run a separate supply?
c_j
Post by c_j » Thu Aug 08, 2019 8:05 pm
Cheers Alfie, set up using the original
Supply to start with including using a switch too. Have since run a separate supply’s both permanent live and switched live for other things like dash cams, usb chargers etc
Cj
ShaneM
Post by ShaneM » Fri Aug 09, 2019 10:48 pm
Cheers cj
Sweet cheers for that. Mine has been ply lined but don't think there is anything behind it so looking to put some sound deadening and insulation behind the ply wood.
Post by petrev » Sat Aug 10, 2019 10:38 am
Hi,
Looking good
Are the new headlights the std. Caddy Xenon units with LEDs ?
Have you got some more details on what you had to do fitting and parts/coding wise ...
Cheers,
Pete
c_j
Post by c_j » Tue Aug 13, 2019 9:50 pm
Hi petrev
Yes it’s the standard head light units
I just ordered a set of h4 led’s that are can-bus compatible.
They go in just like replacing a bulb with no codeing necessary
