Catching side door
DeanWhit
Catching side door
Post by DeanWhit » Fri Aug 09, 2019 5:37 pm
Afternoon,
Has anyone else had the issue of the side door on a SWB caddy catching on the alloy/tyre? The passenger side rear ally sticks out a little further than the driver side. The wheels are 19s
I've removed the plywood and it's still catching a little. Just wondering if this is common and if anyone has a solution.
the67al
Re: Catching side door
Post by the67al » Fri Aug 09, 2019 6:27 pm
Will depend on your offset, i have just fitted 18's with an et of 35, the side door ply only starts to catch when the door is almost fully open, but i will be able to trim down the ply or fit something thinner if i feel the need so not bothered.
Barbel330
Post by Barbel330 » Fri Aug 09, 2019 7:41 pm
Wheel offset is not quite right. Options are, buy different wheels with the correct offset. Have a few MM skimmed off the inside face of the wheels. Space your sliding door rail out with washers. Have RAD modify your door brackets to open wider. Cut a section from the inside of your door and weld it back up.
Instagram: @y_5cuf
DeanWhit
Post by DeanWhit » Fri Aug 09, 2019 8:03 pm
Cheers for the replies, I think I'm going to space the door out. It's literally about 2mm
