Handle swap - school boy error
LS Spark
Post by LS Spark » Sat Aug 10, 2019 6:54 pm
I finally got myself a set of Touran handles and went about fitting them this afternoon. All was going well till I got to the driver side😩
I removed the barrel for the lock, swapped the bits over and when I pushed it back in....something dropped down the inside of the door.
I closed the door and it opened up so I didn’t think too much of it.
Then I locked the door and now the door won’t open. The mechanism works and sounds like it’s unlocking.
I need to get the door open, card off and find whatever fell off.
How can I get the card off with door shut? Or open the door??
Help!!!
Gloss Black Badges, ‘KillAllWipers’ Delete, Van-X tinted HL brake lens, Van-X glove box, Van-X smoked side repeaters
LS Spark
Re: Handle swap - school boy error
Post by LS Spark » Sun Aug 11, 2019 7:10 pm
I got the door open and worked out what the issue was. The pull wire for the handle mechanism came off it’s mount.
Discovered another issue. The screw that holds the lock barrel seemed to be missing the clip that holds it in place is what fell into the door.
I was able to remove the skin enough to get my hand in there and found it. I’m not sure how it goes back in. Currently the lock barrel is loose.
I’ll have a go at removing the skin completely and try to get a better look at the position it needs to go in.
I can chuck some sound deadening in there at the same time
gjseb
Post by gjseb » Sun Aug 11, 2019 10:01 pm
Have a look at this thread did the same thing my self lol
https://www.caddy2k.com/forum/viewtopic ... 48#p317648
LS Spark
Post by LS Spark » Sun Aug 11, 2019 10:29 pm
gjseb wrote:Have a look at this thread did the same thing my self lol
I thought as much. Cheers pal
How did you get it back on?? Take the skin off and remove the handle mechanism?? Or can it go on another way??
gjseb
Post by gjseb » Sun Aug 11, 2019 10:32 pm
Afraid not metal skin off mate but and easy job there is two grommets in the metal skin, wind your window down until you see the glass clamps undo the bolt pull your glass up and I taped it up out off way then pull skin off it has the window mech connected to it and then you free to take in handle off and rebuild and screw it back on I believe there is one screw holding the inner handle which you get at from outside
LS Spark
Post by LS Spark » Mon Aug 12, 2019 7:06 pm
Thanks for your help. Tackled the door this afternoon and won.
Was fairly easy once the skin was off. That was the hardest bit
gjseb
Post by gjseb » Mon Aug 12, 2019 7:46 pm
Top job mate easy once skin off mate 👍👍👍👍👍
