Van shake
Re: Van shake
Will check it out today and get back to ya's
mylo that 6 speed might have to be done soon
1.9tdi, remap, tints, plylined, colour-coded, rs4 alloys, small sound system, 6 speed box, mud flaps.
to come: Touran bumper, coilovers, carpet the rear :0)
Re: Van shake
I think you could be right guys with the flywheel!!!!!
What to do uprated flywheel or 6speed??
Re: Van shake
I'd hope you'd do both when you have the box off!
Go mad fella, bolt on a bigger turbo while your at it and embarrass a few petrol heads!
Gearbox FML or ERF are both 6 speed used on 2003 on PD engines, ERF is the one Mylo went with but the FML I think was found on a lot more.
I'm gonna do a bit more research tomorrow, see what I can dig up.
Anyone know if a DSG box can be retrofitted?
- Eanna tdi
Re: Van shake
6 speed without a doubt. As doc said you might as well once you have box out...jazza wrote:I think you could be right guys with the flywheel!!!!!
T5 2.5TDI 130
Re: Van shake
Yeah sounds like a plan doc ha ha
wot turbo do u think to go with then??
poor van
poor van
Re: Van shake
Might as well go with a big hybrid blower, no point half doin it.
You'll need a injector nozzle upgrade also to get the full benefit of the bigger turbo.
Then the intercooler and exhaust will be the only thing keepin your power below 200BHP.
I've no problem spending other peoples money!
- hedge
Re: Van shake
any turbo off a 1.9 tdi will fit (not passat or a4 ones) look for 130pd ones (looking around 180bhp ish max) and the 150pd one will hit around 200bhp (clutch and flywheel will be the only things stopping you there)Doc wrote:Might as well go with a big hybrid blower, no point half doin it.
unless you have lots of money to burn I wouldn't bother with the hybrid
injectors are in the head and would need to be changed for the turbo (head off job) but will help you hit 200bhp
Standard intercooler is good for around 220ish bhp
if the turbo is changed you have to change the downpipe/mod it to get it to fit (which is the most restrictive part any way)
Re: Van shake
Im going down the shop to check my lotto ticket!!!
If ive won we'll all do it promise
- Eanna tdi
Re: Van shake
What injectors would you reccomend then guys??
Got a bit of time on my hands 2 search around off wok all week with the mumps
Re: Van shake
Been onto sachs no uprated clutch system for the caddy van
Anyone know of a stronger clutch system for us lot?
Ive had my recent flywheel in less then 6months and its gone again!!!!!
Re: Van shake
They may not list the Caddy but did you point out that it's the same engine and gearbox as some MK5 golfs etc?
2008 Caddy DSG : Reflex Silver : Appearance pack : Electric pack : A/C : RNS 510 : MDI : R32 MFSW w/paddles : Golf GT seats : Touran door cards, dash and arm rest : VW Bluetooth : Highline clocks : Cruise : 17" VW Classix wheels : Side rail cover : Side strips colour coded : 140BHP remap
Also in the garage
1989 VW Golf MK1 GTI Cabriolet 20vt
2004 VW Golf MK4 R32
2014 VW Touareg R-Line 245
Fully reg VCDS (vag-com)
- Grizzle
Re: Van shake
If it happens when your cruising along then most likely its a driveshaft check your CV boots also have you had them replaced?? as you may have caught them to late and the shafts will be goosed.
1.9 TDI PD, Custom Code remap 156bhp & 239lbft , rear tints, 16" Golf GT Alloys, VW Mudflaps, H&R Springs, Cruise Control, Koni Sport Dampers, GT Badge, MK5 Golf GTI brakes all round.
Re: Van shake
Could be crap on the flywheel if you tootle about a lot? Try, from a standing start, booting it all the way through the gears. This will clear any rubbish off the flywheel.
Project Caddy
My Blog: http://iphonejailbreaknews.blogspot.com/" onclick="window.open(this.href);return false;
