Hi all, my drivers window only goes down about 10mm everytime you press the switch. also from the drivers side the passenger window wont go down but will go down using the passenger side switch. Anyone else had this problem???
Nicholas
Windows not working properly
Re: Windows not working properly
The drivers side switch is very sensitive to water, it may need to be replaced or you might get away with cleaning the contacts if you fancy opening it up.
it def sounds like the switch, i got snow in mine last december, did exactly the same. its an easy swop for a new one. got mine from ebay!!
I also had the same problem although not on a Caddy.
Bloody kangaroo decided to do some self inflicted cosmetic surgury with the side of my truck, bent the motor bar but his surgury was fatal. YES.
Life is not a journey to the grave
with the intention of arriving safely in a well preserved body
but rather to skid in broadside throughly used up totaly worn out and loudly proclaiming
WOW WHAT A RIDE
WOW WHAT A RIDE
