Wheres your tool kit???
Hey folks,
Basically as title really where is your wheelbrace and tow hoop located???, mines in a polistyrine holder on the passenger seat atm because i cant find a home for it???
Cheers, simon
Cheers, simon
- tommyzooom
Re: Wheres your tool kit???
Mines in with the jack, beside the back door, tho I believe the new model it sits in the overhead shelf in the cab, on the left
mine is in the back with the jack to
hmm you lads whos are in the back are they in a proper holder or not?
- DADDY
Yes proper holder, its a 6 "" thumb screw and a location bracket.
Hmm odd, mines in a perfectly shaped polistyrine holder, wonder if its in a diff place on the maxi?
On mine its in a pre cut foam holder in the over head shelf next to the tyre foam pump and foam stuff .2010 sportline
Yep,overhead on LHD side. Maxi 2011.
mine was in the plastic holder near the n/s rear door but it kept rattling no matter how tight it was now under passenger seat
yeah mines lh side in the upper storage compartment
is there a optional extra sort of liner for that tray???, on my kangoo its got like seperate compartments
cheers, simon
cheers, simon
Mine was in the back right side but have relocated it to under passenger seat.
Same here on a late 2008 modeltommyzooom wrote:Mines in with the jack, beside the back door, tho I believe the new model it sits in the overhead shelf in the cab, on the left
- wai
My MY11 Caddy Maxi Life has it in a polystyrene block at the left hand end of the overhead shelf at the top of the windscreen.tommyzooom wrote:Mines in with the jack, beside the back door, tho I believe the new model it sits in the overhead shelf in the cab, on the left
I have to say that I find this an extremely dangerous place for two lumps of loose metal to be just placed. I have moved mine to one of the two under-floor compartments behind the front seats.
The jack is in one side trim compartment in the lugage area (right), and there is an emergency kit in the other side compartment in the luggage area (left).
^ I was thinking the same! Mines in the rear but the underfloor area is a good call
mine appears to be missing
