towbar wiring
carsounds_dan
towbar wiring
Post by carsounds_dan » Sun Oct 11, 2009 6:56 pm
Hi,
Just wondering if the Caddy has a direct tow bar wiring output in the rear of the van?
I know some of the VW range does this, and I cannot find it shown on any autodata diagrams but there has got to be someone who knows off by heart.
Many Thanks
Daniel
aidy310
Re: towbar wiring
Post by aidy310 » Mon Oct 12, 2009 12:01 am
well one way to find out is to go to the stealers and see if they see the towbar :D
carsounds_dan
Re: towbar wiring
Post by carsounds_dan » Sat Oct 17, 2009 10:14 am
:roll:
I'm looking at fitting a tow bar but as most VW have a dedicated plug located in one of the quarter panels I thought I would ask to see if anyone had found a similar one on the caddy.
Re: towbar wiring
Post by Doc » Sat Oct 17, 2009 10:39 am
Hi Dan,
I think there is a special bus module for the tow bar electrics but it can work out very expensive.
The Dealers advised my mate to wire directly into the loom for his as that was the way they had done all the ones they were asked to fit.
Might just be an Irish solution, the UK price for the module is likely a lot less.
I've found this on ebay.de
2013 1.6TDI, Edition 30 18" BBS Peschara, Caddy4 rear lights, 2016 Polo GTI (mk7 style) steering wheel, TRC front splitter, Relentless Tuning front coilovers, Audi A6 S-Line front seats, mk6 GTI Front & rear Brakes, 3D Colour Premium dash cluster, Caddy life arm rest, Motexion bulkhead, 2016 MIB head unit
Matt@Reflex
Re: towbar wiring
Post by Matt@Reflex » Sat Oct 17, 2009 2:16 pm
Hi. I have just fitted a hidden towbar on my Caddy.
The cheapest way i found was to get one of these (all towbar shops will sell them)
http://cgi.ebay.co.uk/7-Way-Bypass-Rela ... 3ef9492794" onclick="window.open(this.href);return false;
You need this because the Caddy2k has can-bus wiring so just wiring a towbar in the usual way would play havoc with the "bulb not working" warning light.
It comes with instructions and is easy to do. It does need a perminant live from the fusebox but the rest can be wired from behind the drivers side rear inner 1/4 trim. (you will have to feed a wire across to the lhr flasher lamp though.)
The main towbar cable then connects to the relay box.
I ordered the proper caddy wiring kit from VW and when it arrived it was over £100 and also needed hard wiring into the fusebox and an additional relay box so i sent it back to them ;)
carsounds_dan
Re: towbar wiring
Post by carsounds_dan » Mon Oct 19, 2009 4:38 pm
I've sorted it now, I used autodatas pin outs, and used the original inputs onto my custom relay board under the passenger seat.
The relay box contains goodies like "wig-wag" flasher unit, runlock, jump starting points, splitcharging and now towbar wiring.
Tdi-Enns
Re: towbar wiring
Post by Tdi-Enns » Mon Feb 01, 2010 7:39 pm
I've just brought the vw wiring kit and got a shock at all the cables.... in need of some advice..
1) ive brought a detachable witter towbar, will this be ok or do i need westfalia one? ive brought the adapted vw rear beam..
2) Do i need to run these cables and then get vw to plug in the vagcom to activate?
3) would it be better to use a 7 way bypass and does it throw up any faults? i heard that using the vw wiring changes the braking around when towing, ie sends more breaking pressure to the rear?
Tdi-Enns
Re: towbar wiring
Post by Tdi-Enns » Tue Feb 02, 2010 5:03 pm
Also anyone whos done this, what year was your van?
VW-PADDY-TDI
Re: towbar wiring
Post by VW-PADDY-TDI » Tue Feb 02, 2010 7:00 pm
I didnt do it myself was done when i bought the van haven't fully tracked what was done but i do know for sure there is some sort of extra relaying in the rear of the van and it also has a beeper unit when their is a trailor connected. There is also a permanant live taken from the bus bar on the front of the fuse box inside the engine bay which seems to run back under the body ( Haven't looked at it fully as i'm a great believer in dont fix whats not broken and i'm also lazy :D )
http://www.FlyinFinnMotorsport.com
05 Caddy TDI chipped irl custom map 140ish
H13GGE
Re: towbar wiring
Post by H13GGE » Thu Jul 21, 2011 5:41 pm
Just had my towbar delivered today and thought I would check on here for information about fitting. It seems like I can not wire the electrics to the back light as I would have normally done.
Can I connect the cables into the existing wiring loom and put up with the lamp out indicator on the dash or do I have to buy http://www.ebay.co.uk/itm/7Pin-Specific ... 35b3a3f7bf" onclick="window.open(this.href);return false; or is there any other ways to do this??
Tdi-Enns
Re: towbar wiring
Post by Tdi-Enns » Thu Jul 21, 2011 5:50 pm
Hold your hoses, type in ebay 7 way bypass relay. £15 and you can caravan crimp into cables behind the rear light. Mines done on drivers rear light n folded behind the jack etc. Instructions are good. So just comes down to u and a multimeter. Hope that helps
Cd05
Re: towbar wiring
Post by Cd05 » Thu Jul 21, 2011 9:09 pm
Have heard of trailer lights shorting out and passing back up through the van if ya only scotch lock em in, have a unit here where ya bring the constant live to then your signal wires, its designed that if a surge comes back from the trailer that the relay in it will collapse saving the van
Fog lights - Done
Bull Bar - Done
Back ply - Done
Tdi-Enns
Re: towbar wiring
Post by Tdi-Enns » Thu Jul 21, 2011 9:16 pm
Really? Sounds like a bit of an old wives tale that one. Risks have got to be minimal. 3 years strong mine
Cd05
Re: towbar wiring
Post by Cd05 » Thu Jul 21, 2011 9:26 pm
Ive seen it at the local garage, if it was to cause a fire dont think the insurance crowd would be to impressed either but doubt shed get that bad
Fog lights - Done
Bull Bar - Done
Back ply - Done
H13GGE
Re: towbar wiring
Post by H13GGE » Thu Jul 21, 2011 10:04 pm
Brilliant, cheers gyus.
I thought I was going to have to fork out another £140 on top of the £113 already spent on the tow bar and I got a price from a company in Glasgow to supply and fit for £190 which is good.
:D :D :D :D
Who is online
Users browsing this forum: Google [Bot] and 3 guests
