R.A.D Rear wheel centralising plates
Re: R.A.D Rear wheel centralising plates
Went upto RAD and had the plates fitted on my van by Matt and there worth every penny guys.
- Matt@Reflex
Dubwagen wrote:Hi Matt,
I sent payapal payment for these plates followed by another for a side rail cover bracket on 19th september. I also sent an email of confirmation to reflexvw@msn.com
Have you seen these as I have not yet received anything?
Cheers, Martin.
Hi Martin.
I have contacted hq and was told that they were collect on Tuesday so should be with you today.
I know we were waiting for the next batch of axle plates but apologise if you we're not kept informed.
As Doc said I am away for two weeks but will be checking in on here every now and then.
Thanks,
Matt.
good piece
Any more of these?
- Matt@Reflex
Yes.
10 new pairs in stock with 12mm and 15mm options
Matt@Reflex wrote:Yes.
are these needed when only lowering 40 mm all round? does the wheel move to the front of the arch that much?
- chezzy71
Have wondered how these work for ages... Really helpfully, Don't think I will need them but nice to know there's an option...
viewtopic.php?f=13&t=10101
My rear springs have solid locating lugs on the bottom also, I ended up getting the bottom plates machined. Is this an addition to later vans?
- euan tdi
http://www.reflexautodesign.com/RAD_Cad ... 72563.aspx
I just seen you do centralizing plates for the newer Caddys, can I exchange the other type for the new ones ? If you dont ask lol
2013 Highline 2.0 140, KW HLS kit, new set of Helios viewtopic.php?f=1&t=12710
- Banditbarron
- Sales Caporegime
- euan tdi
The others don't fit unless I cut the lug off with an angle grinder, think the "new style" is what I've gotBanditbarron wrote:Your old ones may fit the new one
- Matt@Reflex
Send us an email Euan to ideal.motors@btconnect.com and I'm sure we can sort you out ;-)
- euan tdi
Matt@Reflex wrote:Send us an email Euan to ideal.motors@btconnect.com and I'm sure we can sort you out ;-)
Hi Mat,
The picture of the plates, is that the 15mm setting? Which is the furthest setting to push back away from arch?
Regards
Regards
- gee101a
Where abouts in Northampton is R.A.D?
