ABS Warning light
ABS Warning light
Was driving my Caddy yesterday when the ABS warning light came on- is this a common fault on these? or it is excessive wear in the disks pads? The vans a 104 tdi 57 plate.
Re: ABS Warning light
Have you alloys on?
If so check the rear ABS sensor cables.
Yes, have alloys on, will have a look at them tonight, thanks!
Checked all fuses and connections all OK, plugged into mate's VAG computer and identified the fault as the ABS pump / ecu unit. Anyone know if there's anyone out there that reconditions them? Thanks
Is it the pump or the ecu all car electricronics can repair the ecu it will remove from the pump which means no bleeding if that's whats wrong with it but it will need coding with vcds
