- Tee-caddy
Nice score with the sliding rail cover in viper green.
- Mindak
Having a go at dying my bumpers black!
- Dubbugmitch
- Ske
How was the electric window conversion? Easy enough to do? What kit did you buy?Davebass wrote:had a busy day finishing the interior = electric windows, door cards, gear knob, wiring speakers, footwell lights,
exterior = callipers painted after winter & wash n polish
- Davebass
Dubbugmitch,yea there touran door cards with a lil modding to them ,
SKE ,electric windows and door cards from a touran
i just followed some posts on here and re used my door loom as the facelift is different (surprisingly easy to do),
added power wire from each door to fuse box make sure you put in a constant live so that the motors work with your key when locking van
and i just made sure elec windows was active with vcds ,
hope this helps lads
- Dubbugmitch
Cheers I'm on the huntDavebass wrote:Dubbugmitch,yea there touran door cards with a lil modding to them ,
- METKET VW
Re: RE: Re: What did you do to your van today?
Dear.Maxi4life wrote:Had a good day at the local breakers today, got two maxi life doors complete both with sliding windows. A real shame my vans not that colour I'd love if it was. Will have to get a quote to get them painted white. Got a load of other bits while I was there too
Can I have grab handle part numbers.pls?
LG-D802TR cihazımdan Tapatalk kullanılarak gönderildi
- Maxi4life
front ones 2k3 857 637 A (rears are different)
Mine went on a recovery truck today, small noise coming from timing belt area, checked aux belt and no issues with that. Only just ticked over 10k, disappointed isn't the words. I've only just gotten my mk6 sorted after 7 weeks of gearbox issues
- METKET VW
Thanks Dear..Maxi4life wrote:front ones 2k3 857 637 A (rears are different)
- Maxi4life
Life or combi is different on the bodyshell has brackets welded for fixing. I'm going to just use ply wood screwed to the inner b pillar.
- anoneamus
Found out, the hard way, a disadvantage to having 'privacy' glass: the *&^@s have to break your window to find out there's nothing to steal...
How was the connection to the existing loom? Much cutting into or was it a straight swap?
Love my music, gotta get one of these!
- Adam87
I like
- Mindak
Chopped up my bulkhead so I can see out the back a bit clearer then transferred my bulkhead covers to the inside!
