Yeah but @sean it needs some fog lights....
sent from Huawei using Tapatalk
Yeah I will mate. It’s a slow burner
Stripped my van to bits looking for the cause of my radio interference, it used to be perfect but any other station but radio one and I get awful interference! Am I right in thinking the aerials are in the wing mirrors in a 2014 maxi? Cheers
- BradleyB
Got up early on my day off and washed it , Clay bar and waxed it for the 1st time
- r1lea
Gave mine a bath too
- Grunt
@BradleyB - always wanted to clay my van, but never had the confidence, what it as straight forward as all the YouTube video make out?
I fitted my lowered adjustable drop links from Road nutz...What a difference!
Set them up as per some youtube blokes last night and talk about night and day.....Obviously, no more clunking on small bumps, but the van feels planted on the straights and the corners...,..so smooth! There is obviously no pre-loading on the ARB, so it is able to do the job properly.
best mod so far
best mod so far
- BradleyB
@grunt
Safe way to do is just make sure
Wash car using two bucket method
Take small piece of clay and make flat and soft by rolling and flatten with your hands
Using same soap and warm water
Soap up the area and keep clay flat with no pressure just do a couple of passes and rinse of soap with water
Very simple to do and no need for elbow grease or exspensive pruducts to remove tar etc
- Caddyluv
Otherwise use something like mothers speed clay 2.0.
gave her a bit of botox to front lip and also a nice rinse....
"of all the things Iv'e lost, I miss my mind the most"
Fitted some new stalks with cruise and trip buttons,just need to get cruise coded in and if there’s a way calibrate my range to empty as it seems off
- mikenorman
Highline clocks fitted today at vw retrofit in redditch. That guy Alex is super professional at his work.
- Caddyluv
Sanded and flatted down my paint work to remove drop back marks.
After rotary and DA.
- hef355
Wow! ThTs what i call a detail
- Caddyluv
Cheers mate to bloody hot thou. Had to borrow the mates garage yo do it. I need to get it under the right light. But I think it’s spot on. No more drop back marks.
