james400
Post by james400 »
geo.stronach wrote:Looking forward to when your finished. How did you get them apart?
Just trimed off the plastic weld and poped them off when i come to rebuild them i will replastic weld it should get one done by next weekend
Bluebeard
Post by Bluebeard »
after owning my van for nearly 6 months, today I found out I have bluetooth. so I connected my phone.
ImageUntitled by Stuart McLean, on Flickr
nothing amazing but I did it today and im happy about it. it does seem though that now I can't get access to the mfd, for mpg, range and temps bit. anyone know how I can still see that?
Press and hold the "up" button the the trip stalk to get the MFD menu.
DIKKIES
Post by DIKKIES »
Hello is there any water leakes known on a 2011 2.0 TDi clc motor , water leaking in the front of the motor
Sent from my HUAWEI RIO-L01 using Tapatalk
Ghost-rider
Post by Ghost-rider »
DIKKIES wrote:Hello is there any water leakes known on a 2011 2.0 TDi clc motor , water leaking in the front of the motor Image
If im interpretin ya rite, sounds like u mite av a blocked plenum, its the well undetneath the windscreen, theres drains in there that get blocked up, the water carrys on fillin up untill it starts running down thru your pollen filter area under the dash passenger side, common problem on most carsImage
Palmer006
Post by Palmer006 »
Today I had my van remapped and I am over the moon. It’s a lot quicker, smoother and it shows big increase on mpg. Also fitted my genuine floor mats but need different clips. Couldn’t fit my seat covers as they didn’t fit so got to try see if main dealer will take them back
gibbs812
Post by gibbs812 »
Had the front discs and pads replaced and finally had the rear cigarette lighter sockets fixed. :) :) :)
Jimjams
Post by Jimjams »
Palmer006 wrote:Today I had my van remapped and I am over the moon. It’s a lot quicker, smoother and it shows big increase on mpg. Also fitted my genuine floor mats but need different clips. Couldn’t fit my seat covers as they didn’t fit so got to try see if main dealer will take them back
Where did you get it done?
Geraout
Post by Geraout »
Palmer006 wrote: Wed Feb 21, 2018 2:48 pm Today I had my van remapped and I am over the moon. It’s a lot quicker, smoother and it shows big increase on mpg. Also fitted my genuine floor mats but need different clips. Couldn’t fit my seat covers as they didn’t fit so got to try see if main dealer will take them back
Sounds great.
How have you determined the mpg increase already?
nicolaisam
Post by nicolaisam »
Ordered Cam belt Kit,Water pump,Oil,Oil Filter,pollen filter,Fuel filter,Aux belt,Air filter
And then Ply kit and Anthracite Carpet and insulation and 2 bulk packs of Skins sound deadening..
Today was expensive...
Caddy0802
Post by Caddy0802 »
nicolaisam wrote:Ordered Cam belt Kit,Water pump,Oil,Oil Filter,pollen filter,Fuel filter,Aux belt,Air filter
Holy s**t
Sent from my VTR-L09 using Tapatalk
Palmer006
Post by Palmer006 »
Jimjams wrote: Wed Feb 21, 2018 6:58 pm Where did you get it done?
Geraout wrote: Wed Feb 21, 2018 7:15 pm Sounds great.
I got it done in Norwich by a company called EAC Remapping & Diagnostics. Second time I have used them and great both times. Mpg is only goin off dash but reset on the way there and got 40.7mph and reset again on the way back and got 57.1mpg. Only time will tell
Ricksy1121
Post by Ricksy1121 »
Sprayed my headliner with fabric dye, little bit patchy hear and there but it should look fine when back up, got the storage tray to tackle next.
ricardo_smooth
Post by ricardo_smooth »
Fitted the carpeted ply panels into the van.
Waiting to finish the electrics before I carpet the metal.
Then once that's done i'm leaving it alone for a while! Spent a lot of time on it in the short while i've had it!
Caddyluv
Post by Caddyluv »
Fitted golf R32 breaks and new top mounts. ImageImage
