- Caddyluv
Got to be. More blue. Changing the lower struts to blue ones to. Got HEL Performace in blue to.
Looks sweet. What did you use? How hard was it to do?Ricksy1121 wrote:Sprayed my headliner with fabric dye, little bit patchy hear and there but it should look fine when back up, got the storage tray to tackle next.
dipstr wrote: ↑Thu Feb 22, 2018 10:03 pm Looks sweet. What did you use? How hard was it to do?
Used 4 tins of spray from eBay
https://rover.ebay.com/rover/0/0/0?mpre ... 1755655456
Easy enough to do.
- Drawoc
Just collected from the colour coders...really impressed with the transformation.
Got my 1.9tdi remapped yesterday. 104bhp to 160bhp! Totally delighted with the throttle response. Next job carpeted in the back
- Drawoc
No it’s all the same colour, just the lighting and the dodgy filter I put on instagram.Celticrsmith wrote: Is your side door darker? Colour coding looks good though
- Afield23
Cleaned the black bus today, finally got to see how good the colour coding looks. Booked in for coilovers with Darkside at the end of March and then finally have a break from spending!
- Barbel330
Instagram: @y_5cuf
- james400
Had the work shop all to myself this after noon so done abit more on the Watts linkage lots of measuring done and started on the frame did have to cut the back box off so im driving around now with no box on for 2weeks then the custom one will be built.not much to be seen in photo but I thought I'd put one on
Had to drop it off at the stealers as the injector finally gave in!
Did you have a win on the Lotto?nicolaisam wrote: ↑Wed Feb 21, 2018 8:03 pm Ordered Cam belt Kit,Water pump,Oil,Oil Filter,pollen filter,Fuel filter,Aux belt,Air filter
And then Ply kit and Anthracite Carpet and insulation and 2 bulk packs of Skins sound deadening..
Today was expensive...
- Caddyluv
So today have my Clifford Viper 5104 Remote start with proximity sensor.
- Afield23
Did you fit it yourself?Caddyluv wrote:So today have my Clifford Viper 5104 Remote start with proximity sensor.
