Bl0at3r wrote:
Please share how you mounted the tv
Just a couple pieces of angle and a cheap tv wall mount bracket. Plan on welding it up rather than bolting the angle. Also going to paint it black. I bolted it into where the bulk head fitted with a couple cap head bolts.
2015 Silver SWB Highline 102ps, Day van, MTB overnighter..... with Onsuite
Richie_VW wrote:After work i fitted a cheap fog light kit. Don't think they look to bad.
Easy to fit? Looking to do this as one of the caps has came off and it will probably be just as cheap to fit the fog light kit as it is to replace the cap
2011 1.6 102ps ex BG
225/40/18 ps3 Santiago wheels
schu8888 wrote:Tried fitting an aux cable to mine, realised I have an RCD300 and it doesn't work at least I managed to check the cruise control bits and got them ordered now
I'm really no expert on this but I think you can fit an aux cable into the back of an RCD300, it might need someone with a magic coding wand to activate the aux function once fitted.
brooneye wrote:@D green, it's well worth the effort putting the touran dash in, it finishes off the interior
Itching to finish it off just a trip to the breakers tomorrow for the rest do you know if I really need the two brackets each end it's just that the old ones seem to fit
To be honest I followed a guide on here and as I already had them I changed them whilst I was on and if remember I correctly they are a slightly different shape
