Upgraded my headlights, side lights and number plate lights to LED’s
Replaced steering wheels with alcantara flat bottom version from gti mk5
Easy job?Ben73 wrote:Replaced steering wheels with alcantara flat bottom version from gti mk5
Fitted RCD-330+ headunit. Great upgrade, CarPlay is fantastic!
Mind if I ask where you ordered one? Only seen them from China!Dave W wrote:Fitted RCD-330+ headunit. Great upgrade, CarPlay is fantastic!
Straight swap (not multi function)
Got airbag light on though
Il post picture in a min
Ben73 wrote: Straight swap (not multi function)
- D green
I had the same problem has to be turned off I used my friends snap on scanner
- Caddyluv
Being fussy. What you putting in the missing pat below the airbag.
- D green
Hahahaha I thought that but didn't won't to say anything
Hi Ben73,
The missing badge emblem at the bottom of your steering wheel will look good with the R-Line badge/emblem in there. It is VW part # 1K0419685M44U. A plain brushed aluminium finish is VW part #1Q0419685C3Q7.
Got a silver GT one on order
Also airbag light just turned off within 1 minute of driving (strange ?)
- D green
Luck I drove around with mine on for a month before I had enough of it
