Calamity Kev
Post by Calamity Kev » Fri Nov 23, 2018 8:45 pm
Liam wrote:looking good when are you lowering it
I've got the ST-X kit ready, just waiting for my mate to find time to sort it!
Ride Bikes Drink Beer
Andi licious
Post by Andi licious » Sat Nov 24, 2018 12:11 am
Cheeseburger wrote:Had my first go at carpeting. Sore furry fingers but not at all a bad result I think :)
megavanmats smoke carpet and dark grey clips
Did you do this as a whole sheet on each side or is there some very neat joints going on there?
Rigpig
Post by Rigpig » Sat Nov 24, 2018 7:28 am
Got home from a trip offshore and stuck it straight in for a MOT, straight through with no advisories. Happy with that for a 11 year old van, only got 40k on the clock right enough.
Got hold of Stan the man for my heated seat looms, so they should be en route soon, looking forward to getting those wired in.
JimR
Post by JimR » Sat Nov 24, 2018 2:48 pm
Are you getting heated seats wired into the original system? This was the one comfort feature I missed to check when I got the new Caddy and I would really to get it mounted into the original seat and the original wiring if it's possible without too much work.
JimR
liamcaddy61
Post by liamcaddy61 » Sat Nov 24, 2018 4:18 pm
Today was a good day well kind of haha,
I drove 300 miles to pick up some 65 plate standard caddy seats with gte seats covers on and a van-x arm rest. This part was great nice drive down, meet a top bloke in Slough with a really nice caddy.
I fitted the driver's seat no problems but when I came to tighten the last bolt on the passengers seat rail it seemed really tight. I then took the bolt out cleaned the thread made sure it's wasn't cross threaded then put it back it in. I then got the bolt to the same part as before so I went for it and put a bit of pressure on the spanner to get the bolt to go and it went past the the hard bit, but now the bolt keeps turning doesn't get any tighter or looser and I can't get it out of the rail and because it's one of the bolts on the back end of the rail the seat will only go back so far, any idea on how to over come this. Do I need to buy a new seat base and bolt any suggestions?
Sent from my Pixel 2 using Tapatalk
Rigpig
Post by Rigpig » Sat Nov 24, 2018 10:51 pm
JimR, yeah I bought a set of Golf R heated seats, and more recently picked to a replacement heater / AC control panel with heated seat controls. Got in touch with Stan the man on here and he’s made me up a set of looms, so will be as OEM as can be
anoneamus
Post by anoneamus » Sun Nov 25, 2018 12:40 pm
Had alloys powder coated, fitted VW mudflaps...
Sean1066
Post by Sean1066 » Sun Nov 25, 2018 1:20 pm
At long last I finely go my MFSW fitted
Before
After
Glove box done Image
And then got the engine cover fitted
Looks a lot better now Image
Remapped to 140, Colour coded bumpers, VW Cadiz 18s Vanstyle roof rails, Vanstyle bumper protect.
viewtopic.php?f=13&t=36851
anoneamus
Post by anoneamus » Sun Nov 25, 2018 1:34 pm
Looking good! Excuse the OCD, but it looks like those vent rings need a bit of bending (so that they're flush with dash)...
Sean1066
Post by Sean1066 » Sun Nov 25, 2018 1:45 pm
Yeah your right😉
That little f----- keeps popping out 😡
Did your glove box come with that handle?
If not where did you get it
anoneamus
Post by anoneamus » Sun Nov 25, 2018 1:58 pm
Yeah your right😉
Yeah, some gentle bending over the knee (I'm gonna put you over my knee little f----!), does the trick, just do little bends at a time, so you don't put a kink into the ring... ;)
I got a bunch of extra handles, because they're completely crap and break all the time, so I had one sprayed to see what it would look like. I'm not totally convinced, the spray shop gave it a few goes, but couldn't get it to match the silver of the door handles and other aluminium bits (apparently the door handles are chrome dipped, which was too expensive for an experiment)...
anoneamus
Post by anoneamus » Sun Nov 25, 2018 2:24 pm
Watch out for the brushed aluminium addiction! My Caddy came with aluminium everything (apart from pedals and vent rings). If you wanna go all in, there's pedals, door handles, window switches, handbrake button, gear lever, light switch etc. etc... ;)
Sean1066
Post by Sean1066 » Sun Nov 25, 2018 2:50 pm
anoneamus wrote: Watch out for the brushed aluminium addiction! My Caddy came with aluminium everything (apart from pedals and vent rings). If you wanna go all in, there's pedals, door handles, window switches, handbrake button, gear lever, light switch etc. etc... ;)
Lol
Door handles on order. Been try to find window switches not found the yet
Cheeseburger
Post by Cheeseburger » Sun Nov 25, 2018 2:54 pm
The carpet is very stretchy, the first (n/s) side is all one piece even round the corner pillar - required one slice to remove a little excess in the wheel arch / pillar corner but ridiculously straightforward. The other side I did in pieces but only because i was using up cut pieces (cos i mistakenly did all the small panels first) saving the larger piece for the ceiling. There was plenty of material in the 5m kit to do the two sides, roof panel and all the 'original' clip off panels, and a small bit left over.
TIP: start with the largest bits.
The longer clips may seem like a bit much at 20 quid but they make refitting a lot easier.
anoneamus
Post by anoneamus » Sun Nov 25, 2018 3:01 pm
You're gonna hate me! :lol:
Passenger side: 5K0959855 XSH
Driver side: 5K3959857C XSH
Don't forget the mirror adjustment switch:
1T2959565H XSH
