james400
Post by james400 » Tue May 07, 2019 7:00 pm
So fitted my new lights 2day and started sorting out all the bits I've brought.Image
Cadfull
Post by Cadfull » Tue May 07, 2019 7:02 pm
Fitted Dynamat to the floor and arches. :D
envycommercial
Post by envycommercial » Tue May 07, 2019 7:28 pm
Managed to snap a bolt holding injector clamp down on the 1.6.. drilled it tapped it tightened it up again and pulled thread!!!!
Gone past my patience limit now and a feeling it’s going to be a big job so sending it away tommorow for a quote....... there goes the coil overs for my 1.9 this month :cry:
Sean1066
Post by Sean1066 » Tue May 07, 2019 8:14 pm
Like the lights James
My build thread
james400
Post by james400 » Tue May 07, 2019 8:19 pm
Thanks mate
gjseb
Post by gjseb » Tue May 07, 2019 8:26 pm
What lights are they
james400
Post by james400 » Tue May 07, 2019 8:28 pm
Mk4 lights mate
woody67
Post by woody67 » Wed May 08, 2019 11:18 pm
Not quite today but fitted side bars, now to colour code, remap and lower Image
james400
Post by james400 » Thu May 09, 2019 1:18 pm
Side rail cove has just come Image not bad for £60.65 with the bolts and clips Image
Berger
Post by Berger » Thu May 09, 2019 4:32 pm
ImageImagebrought a mk7 golf door handle to see if I could get it to fit and it worked wasn’t to hard just ordered a passenger one
On my 3rd caddy now :lol:
Blackberry Mk4 150 dsg Highline nav factory xenon lights, heated seats, acc, high beam assist, 19” bbs sr wheels, car mirrors, brushed dash inserts,
Rad sile rail cover, caddy life armrest with leather cover, scirocco leather seats, rear wiper delete fully colour coded , gloss black grills, triple r splitter, genuine rear spoiler , (a lot more to follow)
Instagram caddyad7
Carpy247
Post by Carpy247 » Thu May 09, 2019 5:29 pm
Nice work Berger! Looking good
Sent from my Pixel 2 using Tapatalk
BradleyB
Post by BradleyB » Thu May 09, 2019 9:18 pm
Berger
Another nice mod mate
Is it direct fit or was there some cutting involved
Berger
Post by Berger » Thu May 09, 2019 10:04 pm
Thanks no cutting involved just had to remove the pin holding the original handle in then swap it for the golf 1 there exactly the same the only thing is you can’t buy the handles separately they come as part of the door card because there plastic welded in but wasn’t hard to change and I’m useless at this kind of thing
Instagram caddyad7
owencardew
Post by owencardew » Thu May 09, 2019 10:16 pm
r1lea wrote:
Fri May 03, 2019 5:05 pm
Swapped the stalks to mk7 golf stalks ImageImageImageImage
Hi r1lea,
Would you mind sharing the Part Numbers for your Stalks and Slipring? I am working on fitting the same MFSW to my Caddy Mk4 and it would be great to have some part numbers to order stuff that actually works with the Mk4!
Much Appreciated!
2016 Caddy Maxi 2.0 TDI with a variety of Mods & Retrofits including RaceChip Pro 2, 18" Alloy Wheels, Bi-Xenon Headlamps, 6C0 MFSW, OEM Electric Windows + Electric Folding Mirrors Retrofit, Composition Media Retrofit, Arteon Carbon Leather Electric Seats and Audison Audio Install.
r1lea
Post by r1lea » Thu May 09, 2019 10:33 pm
First of all mate what steering wheel
Are you fitting ?
That will depend on the stalks and the slipring you need
Edit : just seen your other post
The pic you posted of the polo wheel is the one you ideally need
That has red illumination and is without cruise which will work on your van
You’d then keep the cruise control on the stalk
You’d need a highline steering module / slipring, mine was 5K0 953 569 BD
To go for a mk7 golf wheel like mine with cruise on requires an aftermarket module made by “spacewalker”
