Valeting/ daily Maxi build
Exquisitevalet
Re: Valeting/ daily Maxi build
Post by Exquisitevalet » Sun Jul 30, 2017 9:22 pm
Decided to give my set up a new look, still not carpeted although today I did discover the Suzuki mini Moto is very similar colour so had to add it into the mix, happy with this set up for now, geny was overheating up high so put it at the door now
LeeH
Post by LeeH » Tue Aug 01, 2017 1:09 pm
I presume you are on DW too? :P
Exquisitevalet
Post by Exquisitevalet » Wed Aug 02, 2017 4:25 pm
Completed this modification today, picked up some A5 sline seats for an absolute steel, a few dents but these will come out over time, well chuffed Image ImageImageImage
Ricco
Post by Ricco » Wed Aug 16, 2017 12:19 pm
Very smart looking. :D
-GG-
Post by -GG- » Fri Aug 18, 2017 11:20 pm
Looking sharp.
Did the Sline seats drop straight in? Or are they a tight fit cause I was thinking about getting a pair to do the same.
tonyhill
Post by tonyhill » Sun Aug 20, 2017 1:23 pm
Glad to see you have re-positioned your genny, I did think it was in a position which may cause problems.....waayyy better where it is now at the back doors.
Exquisitevalet
Post by Exquisitevalet » Mon Aug 21, 2017 7:20 am
-GG- wrote:Looking sharp.
They are a perfect seat I used the caddy bases and drilled 2 new holes in the back took about 20min total to fit, front 2 holes lined up fine tho
kbcaddy
Post by kbcaddy » Wed Apr 11, 2018 12:20 pm
Looking good
Impressed that you got it all in the back without using the side door (mid) area.
I'm about to set my Caddy up for valeting, so this gives me food for thought!
Not going with such a big tank, as I only want have one as a backup so as to now turn a client away that can't provide me with water supply.
Going for a horizontal tank, and stuck between putting it against the bulk head, or further back between the arches to leave the side door floor at current level. How do you get on with all that weight where you have it?
