My caddy build and face lift
KenTDI140
Re: My caddy build and face lift
Post by KenTDI140 » Fri Jan 12, 2018 3:39 am
the long one wrote:Ken
I need some advice please as you’ve already done the gearbox conversion
Change gearbox with a jlu gearbox and associated driveshafts, starter and complete clutch assembly
Go turn over engine and it’s like a flat battery with starter jamming
Go to bump with a tow the gearbox seems to lock up
Remove starter and the same thing happens - as above
Seems like the flywheel assembly is “tight” to my friends who installed it (one works for Mercedes and the other Audi)
Any ideas ?
Blimey. It should all be a straight swap. So is the engine locked up solid like the flywheel is James against the bell housing ????
Difficult with out actually seeing it but only thing I can think of is may be clutch plate in the wrong way round ???
the long one
Post by the long one » Fri Jan 12, 2018 6:40 am
Yes it seems like the flywheel jamming against the bell housing/engine
Surely there’s a gap between the two ?
I was thinking that the driven plate maybe either faulty or installed incorrectly (haven’t said that to my friends yet as it could be a schoolboy error on their part - don’t want to hurt their feelings)
On a lighter note and this shows that I haven’t done much to the caddy for a while went to TPS this week and found that Marcus had been gone for at least 8 months (I thought he was a nice guy) doesn’t time fly
Thanks for the advice
104 bhp maxi - rcd 510 dab remap 162 bhp facelift highline cluster
KenTDI140
Post by KenTDI140 » Fri Jan 12, 2018 6:43 pm
Lol forgot you were in my neck of the woods. Yea Marcus left ages ago. Shame as his knowledge was very good. I must give him a ring some time and see how he’s getting on.
As for your problem I just can’t believe that the bell housing is hitting the flywheel.
Did everything for the conversion come from the same car.
the long one
Post by the long one » Fri Jan 12, 2018 7:53 pm
The parts came from the same car I believe but can’t be 100% the flywheel/clutch was purchased from darkside developments for an O2Q box so everything should fit
dipstr
Post by dipstr » Fri Jan 12, 2018 8:00 pm
Hi Ken have you checked if the gearbox you have fitted is stop/start? I have fitted a stop start box to none stop start and the starter would not engage properly.
the long one
Post by the long one » Fri Jan 12, 2018 8:04 pm
It’s a JLU gearbox which was a while before stop/start
With the starter it could be something simple which has been overlooked but we’ll see
dipstr
Post by dipstr » Fri Jan 12, 2018 8:07 pm
the long one wrote:It’s a JLU gearbox which was a while before stop/start
Only other thing could be rear mount. Two different length bolts used to mount to gearbox
the long one
Post by the long one » Fri Jan 12, 2018 9:47 pm
Will look into that thanks 🙏
KenTDI140
Post by KenTDI140 » Fri Jan 12, 2018 10:35 pm
I think hunk the holes up through the bottom of the box for the rear dog bone mount are blind holes so u would have to be pretty rough to force them in the wrong hole
the long one
Post by the long one » Sat Jan 13, 2018 10:11 am
Hi ken
Looked at the old box the one that may be causing all the trouble does go straight through into the bell housing so it is possible a longer than necessary bolt may have been used but will find out for sure next week
the long one
Post by the long one » Mon Jan 15, 2018 11:12 pm
update today wrong size bolt fitted on dog bone mount 70mm as oppose to a 35mm one thus locking the flywheel - happy days now :D
KenTDI140
Post by KenTDI140 » Tue Jan 16, 2018 5:52 pm
That’s cool how the hell did they not realise that as bey were fitting it
the long one
Post by the long one » Tue Jan 16, 2018 6:14 pm
maybe they were rushing to finish as they had problems with drive shafts seized in the hubs hello to their new friend 10 ton press - you should know theres always something waiting to go wrong - will have to check cruise control as its not suppose to work with the ecu in that van
KenTDI140
Post by KenTDI140 » Tue Jan 16, 2018 6:16 pm
Cruise should work but you might need to run the extra wire as it prob won’t be there
the long one
Post by the long one » Tue Jan 16, 2018 6:25 pm
cruise control did work fine prior to the gearbox change never needed to run an extra wire - had been working fine since it was installed by DOC/SPACEWALKER - facelift cluster and computer installed at same time MARCH 2013 time will find out after MOT
Who is online
Users browsing this forum: No registered users and 1 guest
