Northern's Silver Caddy
- northern8019
Re: Northern's Silver Caddy
1.9tdi / Calibre CR3 / Lowered-Axle Flip / RNS510 / GTD Seats / Touran Rear Setup
6sp / Touran Bumper / Fogs / Highline Dash / CC / MFSW / Touran Leather Centre Console / now in the 200+bhp club
Thats on my "to do" list lol
- northern8019
How did you fare out with the turbo? Did you make it fit or find one that did?
- northern8019
Turbo is off a BMM/BRM so the exhaust is the same profile and the turbo is cast onto the manifold and a top mountDoc wrote:How did you fare out with the turbo? Did you make it fit or find one that did?
I'd read about people getting a 140pd turbo and swooping out the cartridge for a 170pd. I can confirm this doesn't work!
So I replaced the 140 cartridge wit a new one (if anything the 140 turbo is going to be a limiting factor) but on discussion with Pendle I'm looking at 180/190 hopefully (plenty fast enough)
Using the 150 injectors keeps everything in its comfort zone rather than running OEM at max.
The turbo fitted spot on was just a bit tight using a braided oil feed hose. Looking back the hard piped one might of fit fine buy hey Ho, braided allows flexibility
Nice, I'm thinking you'll be into super MPG with that combination too.
Looking forward to seeing the results.
- northern8019
fingers crossed, its booked in with martin soonDoc wrote:Nice, I'm thinking you'll be into super MPG with that combination too.
- northern8019
- northern8019
- torque777
Have you had it mapped yet?
- northern8019
Don't ask mate!torque777 wrote:Have you had it mapped yet?
BRM with a new cartridge (shat itself)
BRM with original cartridge (shat itself)
This was with running a braided line too, issues are either oil pressure or the feed pipe
Before fitting turbo second time disconnected it a started engine looked to plenty of oil flying out
Needless to say mate assisting me won't fit another turbo unless we use a new oil feed pipe
I could put standard caddy turbo on but defeats the object of fitting 150injectors
Who rates better darkside hybrids or xman?
- torque777
Maybe a complete rebuilt and balanced turbo is needed? I've heard good things from xman turbos but never used before
- northern8019
Yeah my thinking
Xman turbo and darkside oil feed pipe
Gonna message him
Gonna message him
I go to turbo dynamics and get a hybrid built for the job. I'm aiming for 180 bhp so I had a 360 bearing fitted a billet light weight but larger compressor wheel with a 5 deg cut back on the exhaust wheel.
I had thought about using the 150 turbo but as the std caddy ex wheel is 38 MM and the 150 is 43 MM it would have been laggy and I don't like lag at all.
On the std injectors I'm running max duration of 43 deg so can't get more fuel in with out pushing exhaust temps too high so once I have got all my face lift front end done I will get the 150 injectors I have tested and set up. Then I will fit them and map it my self.
- northern8019
Ken I don't know what this means my turbo knowledge is non existent I'm looking for a bolt on really that just requires a remap to make the van fast as hellKenTDI140 wrote:I go to turbo dynamics and get a hybrid built for the job. I'm aiming for 180 bhp so I had a 360 bearing fitted a billet light weight but larger compressor wheel with a 5 deg cut back on the exhaust wheel.
I've messaged Xman he's got a got a hybrid with 52mm billet wheel should be good for 200-210bhp with PD130 injectors (I've read his dint come with actuator n stop screw setup though)
My other avenues of interest are:
Dervtech (emailed them)
Precision turbo services (emailed -but they offer a hybrid with 360deg bearings)
