My new Facelift Caddy
Autokraft
Re: My new Facelift Caddy
Post by Autokraft » Fri Jan 10, 2014 2:26 pm
Well got couple of more bits carpeted today.
Decided to make use of the space behind the drivers seat in the side. Already sound proofed and sealed so carpeted the back in black cloth and cut a section out of my new wooden panel.
Don't think it looks to bad plus an extra bit of storage.
Need to cover my rear door panels and sound proof the side door plus make the panel for it.
pegger
Post by pegger » Fri Jan 10, 2014 5:10 pm
Very nice autokraft.How much would you charge to re carpet the back of my van.Its all carpeted now but fancy another colour as its getting a bit dirty now.Cheers
Tredhed
Post by Tredhed » Sat Jan 11, 2014 11:39 am
Great looking interior, that's pretty much the finish I'm looking for.
Top job, Autokraft!
2015 Pure Grey VW Caddy Maxi 2.0 TDi
Autokraft
Post by Autokraft » Sun Jan 12, 2014 3:39 pm
Pegged you have pm.
Got around to finishing my rear doors.
Covered my speakers with mesh and tacked it in place.
All covered and back in place. Would never know a speakers there as carpet will not push in because of mesh.
Both finished and speakers all working.
Just my side door panel to make now then the roof.
Roger NL
Post by Roger NL » Sun Jan 12, 2014 6:31 pm
A very nice Caddy! My compliments!
Like your mirrors very much!
Autokraft
Post by Autokraft » Sat Feb 08, 2014 12:19 pm
After much sanding and plastic filler the mk6 mirrors are good enough to put on.
Got them to fold as well which added to getting the cover to fit spot on.
Just got to fit my Blue tinted mirror glass now.
Roy_NL
Post by Roy_NL » Sat Feb 08, 2014 12:34 pm
Looking great man!
Do you have more pics from your conversion?
i would like to do it on my own caddy!
Autokraft
Post by Autokraft » Sat Feb 08, 2014 1:37 pm
Did not take pics when I did them but very simple once you get the two mirrors a parts. First one only took me 20 minutes to get it all mounted and wiring completed. Got the second done quicker. Hardest part is getting the spring and retainer back on but easy once you have done it.
Banditbarron
Sales Caporegime
Post by Banditbarron » Sat Feb 08, 2014 1:39 pm
So to confirm that's mk6 mirrors on caddy base? Then graft the piece in to make a good fit?
Roy_NL
Post by Roy_NL » Sat Feb 08, 2014 1:46 pm
Can u tell us how you did it?
How does it fit and what adjustments do you need to make?
Autokraft
Post by Autokraft » Sat Feb 08, 2014 2:34 pm
Banditbarron wrote:So to confirm that's mk6 mirrors on caddy base? Then graft the piece in to make a good fit?
I just separated the mirrors off the mounts. Only mod that needs to be done is to make the hole in the mk6 mirror bigger to go onto the caddy mount then use the spring and spring washer to mount it. All the plastics line up and then use the caddy mirror cap inner part to fill the gap.
From the picture you can see the spring and spring washer. There are four prongs holding it in place. I just got a screw driver under them and levered them out. Comes off with a bit of force from the spring so I got some string and run it through the mount where the cable goes. Once they are off they both separate.
Remove the cabling but make a note of the connector pins. The mk6 mirror mounts from underneath. I got a cone cutter and drilled the alloy mount from the top to separate.
The caddy mount is wider so drilled out the hole in the mirror until it sat all the way down. To get the spring and spring washer back on I used a but G clamp. Find a socket the same as the spring washer. Tape the edge of the washer to the socket then use the g clamp to compress the spring and locate the spring washer.
Tails93
Post by Tails93 » Sat Feb 08, 2014 5:07 pm
Does the aerial fit inside the mk6 golf ones as its very tight in the touran one I've heard?
Well done mate looking good :D
Autokraft
Post by Autokraft » Sun Feb 16, 2014 4:32 pm
Not put the Ariel in the mirror. Bonded it to the inside of the door and works just as good.
Got both of them fitted and tested. Indicators coded in and working also.
Should also be dropping my new wheels off at the powder coater on Thursday.
Tails93
Post by Tails93 » Sun Feb 16, 2014 4:37 pm
Mirrors look great bud, you got any pics where you mounted aerial?
DETAIL
Post by DETAIL » Sun Feb 16, 2014 5:06 pm
I really do like this. Great work.
Who is online
Users browsing this forum: andyvlw and 2 guests
