Maxi life build
Re: Maxi life build
20 k isn't bad but I recon u could have done more with out the extra wear
Most places seem to set the caddy tracking to towing out about ten minutes but I have already found that this causes the inside edges to start to wear so I borrowed a set of optical tracking gauges from a customer of mine and set it to parallel. Now I find the wear is even and no tearing of the inside edge
- torque777
Re: Maxi life build
Mine was set to parallel when I first fitted the spax... But I haven't had it checked for over a year
- torque777
Re: Maxi life build
That's interesting... So is that now parallel
Re: Maxi life build
7 deg of castor sounds crazy. I only run 5.5 deg of castor on my mk2 rs2000 and it took a lot of work and special bits making to get it that high from the std 1/2 a deg
- NZDubNurd
Re: Maxi life build
Quick oil change for the wife?torque777 wrote:...no presents for the wife this Xmas... Lol..
Also gave her a quick oil change as well
Bummer about the tyre!
Re: RE: Re: Maxi life build
I haven't a clue about steering geometry so I wouldn't know if it's parallel or not. The guy who did it said it was OKtorque777 wrote:That's interesting... So is that now parallel
Sent from my HTC One_M8 using Tapatalk
- torque777
Re: Maxi life build
Fair enough
Re: Maxi life build
If you do get it checked on a Hunter machine be sure to post the results on here so I can compare.
- torque777
Re: Maxi life build
Yes I will as soon as I get it done
- torque777
Re: Maxi life build
So got bought these for late Xmas present... Caddy tinted cross lights
- horace01
Re: Maxi life build
Looks good Nic. I much prefer these to the new 2016 taillight. I'm actually suprised how many people have jumped on the 2016 taillight band wagon. Each to there own though.
Sent from my HTC 2PS6200 using Tapatalk
- torque777
Re: Maxi life build
Thing is it's made these a lot cheaper now, only paid £40 for these and they are like new
- brooneye
Re: Maxi life build
Liking the look of these, I was thinking of getting the new lights but I have changed my mind now
- Maxi4life
Re: Maxi life build
I'm in two minds about these, but I thought that the facelift headlights match caddy 4 lights more. If I had a prefacelift id stick with these ones.
