Maxi life build
MattMan
Re: Maxi life build
Post by MattMan » Thu Oct 05, 2017 8:14 pm
Yeah thinking im gonna have to drop the back box off to do it. Not ideal but when its the last two bushes on the whole van that need doing i cant leave it or it will do my head in lol.
Maxi4life
Re: Maxi life build
Post by Maxi4life » Sat Oct 07, 2017 12:24 pm
torque777 wrote:
Tue Aug 29, 2017 7:23 pm
I used fab from autobrite direct, watered down to 1-4, I scrubbed seats with it then used a wet vac with just hot water then when dry I used gtec fabric protection
Just something worth mentioning is to use cold water first as hot water can and does fix some stains into fabric and make them very stubborn.
torque777
Re: Maxi life build
Post by torque777 » Sat Oct 07, 2017 1:30 pm
So I got these in the post today, used link supplied by Andrew mcknight
Maxi4life
Re: Maxi life build
Post by Maxi4life » Tue Oct 10, 2017 4:19 pm
Where did he post the links Torque777? It's unbelieveable that when you buy a van at a premium price there are lots of little bits that don't come fitted as standard.
torque777
Re: Maxi life build
Post by torque777 » Tue Oct 10, 2017 5:36 pm
Maxi4life
Re: Maxi life build
Post by Maxi4life » Wed Oct 11, 2017 11:59 am
Cheers very much!
torque777
Re: Maxi life build
Post by torque777 » Wed Oct 11, 2017 12:25 pm
No problem
hodge725
Re: Maxi life build
Post by hodge725 » Wed Oct 11, 2017 3:19 pm
This Caddy is amazing, keep up the good work.
mark1a
Re: Maxi life build
Post by mark1a » Wed Oct 11, 2017 9:19 pm
https://rover.ebay.com/rover/0/0/0?mpre ... 2176790325
Thanks for this, couple of 30mm bungs on their way to me as well.
2017 Blackberry Maxi Life 150TDI OEM+
Brescia Clubsport 18” | OE Xenons | Limo tints | Vanstyle side bars | Climair wind deflectors
H&R / Darkside lowering | TRC front splitter
Android HU | 4G WiFi
torque777
Re: Maxi life build
Post by torque777 » Wed Nov 01, 2017 4:30 pm
Well today I drove upto skipton car radio and saw Peter and Dave who installed one of there plug and play phoenix gold component system with phoenix gold crossovers, was a great morning I got to drink tea while watching them fit the components and crossovers and road kill sound deadening inside the speaker inclosure and around speakers, the kit is impressive and uses factory plugs so you could return it to standard afterwards if wanted, the fit was great and the sound quality was enough to leave me speechless for once, the drive home was great with clear quality treble and punchy bass which I could here above my straight through exhaust, bare in mind mine allready had factory tweeters and upgraded door speakers as it's the life model so in a standard van you can imagine the improvement, pop along and see the lads or call them, you won't be disappointed in their plug and play kits, they also do them for transporters and crafters
torque777
Re: Maxi life build
Post by torque777 » Wed Nov 01, 2017 5:53 pm
Photos ImageImageImage
Spiff
Re: Maxi life build
Post by Spiff » Fri Nov 03, 2017 4:01 pm
do you ahve the exact name fo this front sett?
looks good, would like something like this my self :)
torque777
Re: Maxi life build
Post by torque777 » Fri Nov 03, 2017 4:28 pm
They were phoenix gold sx series... If you speak to skipton car radio Peter Preston will sort you out, he does kits with vibe, phoenix gold, focal etc and includes looms with quadlock, crossovers, road kill sound deadening and component speakers
Spiff
Re: Maxi life build
Post by Spiff » Sat Nov 04, 2017 12:38 pm
its a bit far away from me unfortunetaly, and i can order some Phoenix Gold components at work but not the sx series :(
allways like phoenix gold, so seeing you had this in your car gave me some ideas now :)
is it the 6,5" set?
torque777
Re: Maxi life build
Post by torque777 » Sat Nov 04, 2017 12:45 pm
Yes I believe it is... They do mail order kits also
