Maxi life build
LeeH
Re: Maxi life build
Post by LeeH » Sat Nov 04, 2017 10:42 pm
Hull area?
Sent from my iPad using Tapatalk Pro
torque777
Re: Maxi life build
Post by torque777 » Sat Nov 04, 2017 10:44 pm
Sowebry bridge business park unit 4
torque777
Re: Maxi life build
Post by torque777 » Sun Mar 18, 2018 12:28 pm
Ok so not posted in a while.. Nothing much happened and no money spent on the caddy yay!!.. But my rear brake light has exploded over night, had to super glue it back together and do a temporary fix for now, new one on order. ImageImage
torque777
Re: Maxi life build
Post by torque777 » Sun Mar 18, 2018 12:31 pm
Another breakage is the gas ram off the single rear seat, the ball snapped off out the seat so will need to drill the seat out and re tap, new one is only £3 from tps if I can get round to do it ImageImage
torque777
Re: Maxi life build
Post by torque777 » Sat Apr 07, 2018 9:24 pm
So mot time and number plate lights have died... Spent ages trying to get them to work but the terminals are broken, so decided to hard wire them..
torque777
Re: Maxi life build
Post by torque777 » Sat Apr 07, 2018 9:25 pm
Fixed the gas ram on the rear seatImageImageImage
torque777
Re: Maxi life build
Post by torque777 » Sat Apr 07, 2018 9:27 pm
Passed mot but had advisory on front tyres, only done 10k but down to 3mm and side wall worn Image
torque777
Re: Maxi life build
Post by torque777 » Sat Apr 07, 2018 9:28 pm
Also fixed rear brake light
torque777
Re: Maxi life build
But the seal is too thick
slipperjake
Re: Maxi life build
Post by slipperjake » Sat Apr 07, 2018 9:51 pm
That’s a lot of side wall wear for a 10k old tyre? I’ve seen a few caddy’s now with exploded 3rd brake light? What do you think caused it? Ice?
torque777
Re: Maxi life build
Post by torque777 » Tue Apr 10, 2018 8:15 pm
Yes the seal started to come out the side, and water got in and I think it froze then and became brittle, the tyre side wall has wear because I constantly go over speed humps and they rub the side walls
Re: Maxi life build
Post by Doc » Tue Apr 10, 2018 8:28 pm
Wow, that's crazy wear for speed bumps, I'd bring it up with your local council if your having to replace all 4 tyres too often because of their speed bumps.
KenTDI140
Re: Maxi life build
Post by KenTDI140 » Fri Apr 13, 2018 6:58 am
torque777 wrote:Yes the seal started to come out the side, and water got in and I think it froze then and became brittle, the tyre side wall has wear because I constantly go over speed humps and they rub the side walls
Was that wear only on one side or on both inner and outer edges.
Pepsi
Re: Maxi life build
Post by Pepsi » Fri Apr 13, 2018 9:04 am
torque777 wrote:Also de badged rear and modded mirrors to stop whistle
Hi great van. A good read.
What’s the wing mirror mod?? The whistle is driving me crazy. Got some wind deflectors thought would stop it but doesn’t.
Afield23
Re: Maxi life build
Post by Afield23 » Fri Apr 13, 2018 9:31 am
I just put a thin layer of foam tape in between the mirror and the base, that's where the whistling comes from. I believe there is a how to on it somewhere
