Maxi life build
Pepsi
Re: Maxi life build
Post by Pepsi » Fri Apr 13, 2018 9:36 am
I’ve seen the how to bit all the photos are not visible. Photo bucket.
Any chance of putting up some photos?
Would be really appreciated
JD2k
Re: Maxi life build
Post by JD2k » Fri Apr 13, 2018 9:39 am
This google Chrome extension might help you out with photobucket?
https://caddy2k.com/forum/viewtopic.php?f=2&t=33073
18" VW R Talladega|ST X Coilovers|MK7 Golf R Seats|Pioneer Audio
https://www.instagram.com/jdcaddy2k/?hl=en
Pepsi
Re: Maxi life build
Post by Pepsi » Fri Apr 13, 2018 9:54 am
Thank will need to fire up the laptop now lol. Use tap a talk app
torque777
Re: Maxi life build
Post by torque777 » Sun Jul 01, 2018 1:11 pm
Doc wrote:Wow, that's crazy wear for speed bumps, I'd bring it up with your local council if your having to replace all 4 tyres too often because of their speed bumps.
Yep doc it's rubbish, it's mainly fronts as the rears seem to sit further out I think, council are not interested, a few have complained before
torque777
Re: Maxi life build
Post by torque777 » Sun Jul 01, 2018 1:12 pm
KenTDI140 wrote: Was that wear only on one side or on both inner and outer edges.
Hi Ken it's just inner edge on fronts and the writing on rear wheel inner side walls
KenTDI140
Maxi life build
Post by KenTDI140 » Mon Jul 02, 2018 6:28 am
If it’s just the inner edge I would make sure the tracking is dead parallel not toeing out as almost all tyre places seem to set it.
I found that with the van being lowered the needed tracking to maintain even tyre wear changed from std
For the rears are u sure the tyre isn’t touching the plastic wheel arch guard as I would think it’s impossible for that to come in contact with the road
torque777
Re: Maxi life build
Post by torque777 » Sat Aug 25, 2018 6:48 pm
Hi Ken the inner edge damage is from the speed bumps I travel over every day.. The tyres pass either side but rub on the raised edge of tarmac bump
torque777
Re: Maxi life build
Post by torque777 » Sat Aug 25, 2018 6:54 pm
So had some knocking from rear suspension and convinced myself that one of my gaz dampers was playing up, took a bit to find but a rear drop link had come loose some how, nut was very tight so think maybe I hadn't seated it right but it's took some time to come loose, half a turn on nut and job done considering it sounded like it was falling off
torque777
Re: Maxi life build
Post by torque777 » Sat Aug 25, 2018 6:56 pm
Managed an all time best on mpg by setting cruise on motorway.. Never seen this.. Just wish I had started journey when it was a full tank Image
torque777
Re: Maxi life build
Post by torque777 » Sat Aug 25, 2018 6:57 pm
Had spiderman Park next to me with his spider 3 wheeler bike Image
torque777
Re: Maxi life build
Post by torque777 » Sat Aug 25, 2018 6:59 pm
Had to drive round to the rear of my house which is single lane road to load stuff for tip, unfortunately I managed for the first time ever to catch the curb.. Sulked all weekend ImageImage
torque777
Re: Maxi life build
Post by torque777 » Sat Aug 25, 2018 7:01 pm
So after this have decided to take a different direction, I'm going to be buying some new Mercedes Vito 17"steels, having them painted and fitting 205/50/17 tyres.. Should be a better ride and maybe improve mpg but that may be wishful thinking
torque777
Re: Maxi life build
Post by torque777 » Sat Aug 25, 2018 7:02 pm
Did another change this week, gone is the blue body colour dash surround and now is gloss black to pick up on stereo ImageImage
NZDubNurd
Re: Maxi life build
Post by NZDubNurd » Sat Aug 25, 2018 10:01 pm
If you want them to poke out a bit more, you can get Tiguan 17" steels. Same dimensions but with ET38, instead of ET50 on the mercs.
Of course in normal VW fashion here in NZ, the VW part costs 50% MORE than the merc part.
torque777
Re: Maxi life build
Post by torque777 » Sat Aug 25, 2018 10:25 pm
You can get the Vito steels in et38 too
