Maxi life build
KenTDI140
Re: Maxi life build
Post by KenTDI140 » Sun Aug 26, 2018 11:43 am
Hey torque how’s it going.
Just catching up now as it’s been such a busy year for me with work, getting my garage and work shop built and crashing my caddy
Funny u should say your rear drop link came loose. As I had the same problem. The same one came loose twice. I think if they are not quite tight enough they move slightly on cornering then as it wears they just clunk worse and worse.
Sorry to see u clipped a wheel. Did the same my self earlier in the year but luckily it was only one chip so I touched it in.
torque777
Re: Maxi life build
Post by torque777 » Sun Aug 26, 2018 12:13 pm
Hi Ken, I've been away from here for a bit and are just catching up, love what you are doing with that inlet manifold.. I've neglected the caddy a bit tbh.. Lost a bit of love for it as the paint on the front end is degrading badly now.. And with not having the budget to sort I lost interest a bit
torque777
Re: Maxi life build
Post by torque777 » Sun Aug 26, 2018 12:14 pm
No idea what caused this but paint on bonnet is ruined ImageImageImage
Caddyluv
Re: Maxi life build
Post by Caddyluv » Sun Aug 26, 2018 12:16 pm
Wow wtf. That looks like someone has washed it with a scotch bright. Sorry man.
torque777
Re: Maxi life build
Post by torque777 » Sun Aug 26, 2018 12:19 pm
It's really strange.. It's scratched but in weird patterns, I always wash by hand with two buckets and grit guards
Caddyluv
Re: Maxi life build
Post by Caddyluv » Sun Aug 26, 2018 12:22 pm
Wounder if you can heavy compound it with a machine. I guess the state it’s in. Worth a try. Cheaper than repainting it. Sorry man. Vandals???
torque777
Re: Maxi life build
Post by torque777 » Sun Aug 26, 2018 12:36 pm
I've tried that with a DA and compound but it's too deep, I park my caddy nose in so if it was vandals I would think they would do the rear..
KenTDI140
Re: Maxi life build
Post by KenTDI140 » Sun Aug 26, 2018 1:13 pm
That’s to do with the lacquer it’s shrunk and cracked. Nothing to do with scratches.
It’s possibly cheap lacquer or a reaction. I will ask my sprayer and see what he says.
torque777
Re: Maxi life build
Post by torque777 » Sun Aug 26, 2018 1:14 pm
I've had it 4 years and the bonnet was painted at garage before I picked it up without realising
Giddy
Re: Maxi life build
Post by Giddy » Sun Aug 26, 2018 1:15 pm
I'm pretty sure I've seen this before. Looks like lacquer coming off as result of poor repair, judging by the pictures, anyway.
torque777
Re: Maxi life build
Post by torque777 » Sun Aug 26, 2018 1:24 pm
I really need complete front end repaint but can't afford it
PaulC61
Re: Maxi life build
Post by PaulC61 » Sun Aug 26, 2018 1:55 pm
Sorry to see the state of your bonnet, I freak out when I see just one new scratch appear.
How long has the bonnet been in this condition?
If it's only the bonnet, the only thing I could think of was if you had much snow and ice on it during the bad weather in February. I know that there was dark layers in the snow that built up on the bonnet of mine and when the snow melted there was a dark gritty layer all over the caddy. Trying to clear the snow/ice off may have caused some of the scratches.
torque777
Re: Maxi life build
Post by torque777 » Sun Aug 26, 2018 2:21 pm
That could be it.. I knew it wasn't good but took the DA to it and its filled the scratches with the compound so now you can really see it
dan@biali
Re: Maxi life build
Post by dan@biali » Mon Aug 27, 2018 8:09 am
It might be that the DA won’t get rid of those but a rotary will. I’ve been using my DA recently and even with a micro fibre cutting pad and the coarse compound it didn’t remove swirls and took quite a few passes to remove the problem I had with water spots.
As it’s been painted it will be slightly tricky to assess but might be worth talking to a pro detailer to see how much they would charge and if it’s possible to sort. They may even feel confident they can wet sand that and then polish it.
torque777
Re: Maxi life build
Post by torque777 » Mon Aug 27, 2018 9:07 am
I think it's past that, tbh the paint is a poor match anyway and has faded and has a milky sheen to it now, as said it's not even got clear coat on it just a gloss finish.. Just need to save the money to get it painted again I think
