Horace's Caddy
- horace01
Re: Horace's Caddy
All done. Golf GTi pedal and both puddle lights in.
Messed up the holes for the lights a wee bit but they fit OK. I just used a some epoxy to fill the little gap. As they are on the bottom of the mirrors you cannot see them anyway.
Happy with the result.
Sent from my HTC 2PS6200 using Tapatalk
- tommyzooom
Re: Horace's Caddy
Looking good dude
- torque777
Re: Horace's Caddy
I need to do the mirror light mod
- DentCaddy
Re: Horace's Caddy
Do the interior ones keep on while you drive like the Audis?
Looks awesome
Enviado desde mi iPhone utilizando Tapatalk
Looks awesome
- horace01
Re: Horace's Caddy
No. They switch off so work as footwell lights unlike the Audi lights which are really ambient lighting.
Easy enough to change that though. You can just wire them up to always be on.
I personal do not like ambient footwell lights.
Mine look very bright in the photos but quite subtle in real life. I've turned them down to 70% brightness with VCDS.
Sent from my Nexus 9 using Tapatalk
Thanks. Also thanks for the looms and sourcing the puddle lights for me from TPS which we don't have here in Australia. Unfortunately one of them had a loose piece of plastic in it and rattles. I'm hoping as it's on the outside of the van I won't notice it. If I do I'll crack it open and remove it.tommyzooom wrote:
- Arny26caddy
Re: Horace's Caddy
Did the rear leaf spring braces make a lot of difference?
- horace01
Re: RE: Re: Horace's Caddy
Didn't get them installed. Also as I have had to raise my van up one hole at the back I now don't think they well fit.Arny26caddy wrote:
I'm still messing about with the height of the van. I found once everything has settled and I added the flooring and the bed I was wearing holes in the rear wheel well liners. I have both raised the leaves by one hole and removed the centralising plates. I now want to lower it back down one hole with no centralising plates an see how it goes.
Re: Horace's Caddy
Congratulations its an amazing job I've learned it all and feel as at school
- torque777
Re: Horace's Caddy
You fitted your hanger spacers yet?
- Maxi4life
Re: Horace's Caddy
Just the kind of thing I want to see, well done!
- horace01
Re: Horace's Caddy
Fitted new windscreen wiper blades this morning. Interestingly you cannot buy refills here in Australia for the Bosch wipers. Not somewhere I could find anyway and I've spent loads of time trying to get some locally. Plenty of places wanting to sell me complete blades for $75.00 for a pair though.
That just pisses me off. Wasteful to replace a perfectly serviceable set of wipers. Crap for the environment and profiteering at its worst. Gotta loath our modern day throw it away society.
OK rant over....i ended up getting them from
http://www.wiper-blades-refills.co.uk
$27.65 including shipping to Australia.
I also fitted the leaf spring rear hanger braces after lowering the van another hole.
Seems a bit more solid in the rear. I only went for a quick blast around the block, fully around 3 roundabouts and over 12 speedhumps (gotta love the suburbs). I'll see how they go over the next couple of weeks.
As Mick Jagger suggested I may have to "paint it black" though.
Unfortunately when I was under the van I noticed the bottom of the tank is covered in diesel. I cleaned it up and couldn't see any leaks but when I put my hands up the top I found fuel pooled in the top part where the union nut and seal ring are. Looks like I'm going to have to drop the tank to investigate further.
I do wonder if this has happened from overfilling the tank. I did brim fill it last week, which I never normally do. I did so because I also added a 500ml bottle of Liquimoly Fuel System cleaner as the van has been parked up for the last 6 weeks as I have not been able to drive with my broken ankle.
- Barbel330
Re: Horace's Caddy
I'll be interested to see how you get on with those hanger braces mate, keep us posted.
Instagram: @y_5cuf
- torque777
Re: Horace's Caddy
It shouldn't do that with brimming it, when I get paid I always fill mine to the brim every time, mainly to see how many miles I get to the tank
Re: Horace's Caddy
Did you notice any difference in the drive with the hangers?
- horace01
Re: Horace's Caddy
Will do.Barbel330 wrote:I'll be interested to see how you get on with those hanger braces mate, keep us posted.
I agree. I suspect the return line is cracked at the nipple. My thinking is if it was the send line I would notice the difference when driving or get an engine light due to a drop in fuel pressure. Mind you I'm just guessing here and will do a bit of reading over the next couple of days.torque777 wrote:It shouldn't do that with brimming it, when I get paid I always fill mine to the brim every time, mainly to see how many miles I get to the tankk
To quote my post above "Seems a bit more solid in the rear. I only went for a quick blast around the block, fully around 3 roundabouts and over 12 speedhumps (gotta love the suburbs). I'll see how they go over the next couple of weeks."slipperjake wrote:Did you notice any difference in the drive with the hangers?k
