LSZ caddy
cadmad
Re: LSZ caddy
Post by cadmad »
Gaz9977 wrote:Alright pal, loving the mods.... How you finding that head unit?.... Its driving me insane trying to choose one lol
I like the head unit it suits the van and didn't cost a fortune. Has everything I wanted on it and more. Will be fitting the dab box soon.
cadmad
Re: LSZ caddy
Post by cadmad »
Luke_rs4 wrote:Looking good mate. I have recently brought a caddy i will be following this thread. Good mods :D
Thanks Luke.
CaddyD
Re: LSZ caddy
Post by CaddyD »
Hi there I'm new to the forum and love hat your doing with the van :D also I see you have the sdi engine how do you find ? Is it really as bad as made out ?
cadmad
Re: LSZ caddy
Post by cadmad »
CaddyD wrote:Hi there I'm new to the forum and love hat your doing with the van :D also I see you have the sdi engine how do you find ? Is it really as bad as made out ?
It's a good engine little To go wrong with it. It's never going to break any land speed records but it sits comfortably in traffic I never have any problems keeping up or even over taking. I bought the sdi as I work close to home and it's economical and at the end of the day it's my daily work van.
shanky887614
Re: LSZ caddy
Post by shanky887614 »
ive got an sdi van and like a few others im having the engine swapped to a tdi. im planning on keeping it at least a few years, its a workvan but its also a toy otherwise i would have bought something boring and shitty like a ford
Sent from my SM-G900F using Tapatalk
cadmad
Re: LSZ caddy
Post by cadmad »
so scanned the van today as my steering wheel has stopped working and have numerous faults registered : (
Saturday,18,June,2016,19:51:48:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
http://www.Ross-Tech.com" onclick="window.open(this.href);return false;
VIN: WV1ZZZ2KZAX129954 License Plate: EU10 LSZ
Mileage: 38255 Repair Order: #1
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1110
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 016 LF HW: 03G 906 016 DR
Component: R4 2,0L EDC 0001SG 2977
Revision: 12345678 Serial number: VWX7Z0J43NH003
Coding: 0000071
Shop #: WSC 00082 210 80597
VCID: 72EC42E76DBC86AE5B-8026
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0020801
Shop #: WSC 35110 377 00154
VCID: 76E47EF701D49A8E77-8022
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 2K0 820 047 BM HW: 2K0 820 047 BM
Component: Climatic PQ35 143 1515
Revision: 00143033 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 71EE4DEB68BABDB6A2-8024
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 01000003941161
Coding: A0805F030004100057000000000000000008FB075C000120000000000000
Shop #: WSC 35110 377 08192
VCID: 326C82E7AD3CC6AE9B-8066
Subsystem 1 - Part No: 1T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 040510 021 0512
Coding: 00038805
Shop #: WSC 35110
1 Fault Found:
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 164
Mileage: 61566 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 2Q AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR07HK1P
Coding: 0012881
VCID: 7DF661DB24E2C9D636-8028
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000701
Shop #: WSC 12345 102 209715
VCID: 7AFC6AC735CCFEEE13-802E
1 Fault Found:
02071 - Local Databus
014 - Defective
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5M0 920 983 A HW: 5M0 920 983 A
Component: KOMBI H05 0505
Coding: 470A00
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
VCID: 326C82E7653CC6AE9B-8066
Coding: 470A00
ASAM Dataset: EV_Okmbi_UDS_VDD_RM09 A04716
ROD: N/A
No ASAM data for: "EV_Okmbi_UDS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 070510F1001877
Coding: 89801F06000202007401
VCID: 69DE258B406A4576EA-803C
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 164
Mileage: 61566 km
Time Indication: 0
Date: 2016.06.18
Time: 19:47:09
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0505
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDDR_M09 A03709
ROD: N/A
VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Immo_UDS_VDDR_M09" (VW36 *)
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000626
VCID: 4898C00F3BA05C7ED5-801C
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 008B0C287F2D840F48DA030000C0
VCID: 0008182F5310A43E5D-8054
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:05)--------------------------
LewisDunlop
Re: LSZ caddy
Post by LewisDunlop »
Really nice looking van bud! I'm also from Northern Ireland, from Bangor maybe see you about! Keep up the good work
cadmad
Re: LSZ caddy
Post by cadmad »
Cheers Lewis. I done the omniplex in Bangor years ago haven't been about it in a long time but usually driving around that direction.
LewisDunlop
Re: LSZ caddy
Well hopefully see you about!!
Jcalvert95
Re: LSZ caddy
Post by Jcalvert95 »
cadmad wrote:Image
Hi mate, how did you remove the badge?
Jack Calvert
Caddy Maxi 1.6 TDI
Carlisle Cumbria UK
SaMmY8444
Re: RE: Re: LSZ caddy
Post by SaMmY8444 »
tovtm wrote: How did you get this off buddy is it just stuck on with double sided tape?
Does the rear badge screw out? Wanting to change my rear badge bk to the silver one currently have a matte black one but dint like it
Sent from my D5503 using Tapatalk
SaMmY8444
Re: RE: Lsz caddy
Post by SaMmY8444 »
cadmad wrote: This is my favourite little touch lol
Were did u get the vw badge for the window control?
shanky887614
Re: RE: Re: RE: Re: LSZ caddy
SaMmY8444 wrote: Does the rear badge screw out? Wanting to change my rear badge bk to the silver one currently have a matte black one but dint like it
its glued on or with sticky tape
cadmad
Re: LSZ caddy
Post by cadmad »
It was on eBay 7£ if I remember rightly
cadmad
Re: LSZ caddy
Post by cadmad »
Hi mate, how did you remove the badge?[/quote]
Hair dryer and plastic pry tool comes off no bother. But have heard of ones on with gripfill and sikatak which if that's the case you will have fun removing it.
