LSZ caddy
Caddyluv
Re: LSZ caddy
Post by Caddyluv »
Wounder if the aerial cable is damaged and as you drive the disturbance knocks out the antenna. What I would try is to disconnect the antenna wire from the back see if it has a built in warning on the radio says antenna is disconnected if it does then I would assume it’s the wiring not the antenna. So might have to do a bit by bit diagnostic.
xfinity
Re: LSZ caddy
Post by xfinity »
Really like the subtle mods you're doing to this. Keep up the good work!
Did you get the multi function buttons on the steering wheel to actually work?
cadmad
Re: LSZ caddy
Post by cadmad »
Caddyluv wrote:And you have connected the aerial???
Yes everything connected and power going to the antenna. Am at a loss.
cadmad
Re: LSZ caddy
Post by cadmad »
xfinity wrote:Really like the subtle mods you're doing to this. Keep up the good work!
Thanks buddy. Yes everything working had a mare with swcm’s ended up buying a brand new one.
Caddyluv
Re: LSZ caddy
Post by Caddyluv »
There are a couple of stereo guy on here. Open a separate thread to ask the question. I bet your get the answer. Or for a £10 I’m sure your local stereo guy will have the answer straight away. Asking them I’m sure they will no. For me it sounds like you have a interference problem.
cadmad
Re: LSZ caddy
Post by cadmad »
Caddyluv wrote:There are a couple of stereo guy on here. Open a separate thread to ask the question. I bet your get the answer. Or for a £10 I’m sure your local stereo guy will have the answer straight away. Asking them I’m sure they will no. For me it sounds like you have a interference problem.
Thanks buddy yeah think your right might try routing the power in a different direction to the aerial lead.
Caddyluv
Re: LSZ caddy
Post by Caddyluv »
Think that would help.
CSWMINTY
Re: LSZ caddy
Post by CSWMINTY »
This thread is brilliant and terrible in equal measures! Excellent work on the Caddy, but I now want to do all of the mods to mine (I only brought it to carry bikes in)
cadmad
Re: LSZ caddy
Post by cadmad »
CSWMINTY wrote:This thread is brilliant and terrible in equal measures! Excellent work on the Caddy, but I now want to do all of the mods to mine (I only brought it to carry bikes in)
Yeah this group gets expensive lol.
hiawathaa
Re: LSZ caddy
Post by hiawathaa »
cadmad wrote:Image
Finally in and working. Getting air bag error which am guessing is because steering wheel not coded in anyone know if that is the case?
Realy nice Image. Do you know if the golf R mk6 wheel fits?Image
Sent fra min SM-G930F via Tapatalk
cadmad
Re: LSZ caddy
Post by cadmad »
hiawathaa wrote:Realy nice Image. Do you know if the golf R mk6 wheel fits?Image
Am pretty sure it does but I know the cruise control buttons are not straight forward. Doc would be the guy to ask about it.
Re: LSZ caddy
Mk6 R doesn't have cruise control. It's a straight forward swap, look at Spacewalkers how-to for some useful guidelines.
hiawathaa
Re: LSZ caddy
Post by hiawathaa »
Doc wrote:Mk6 R doesn't have cruise control. It's a straight forward swap, look at Spacewalkers how-to for some useful guidelines.
Thanx Doc ImageImageImage
Kap812
Re: LSZ caddy
Post by Kap812 »
cadmad wrote: Tue Mar 01, 2016 4:33 pm Image
Absolutely love the instrument cluster and wheel!! Was it a big job to get it coded up? Been thinking of doing the same upgrade
cadmad
Re: LSZ caddy
Post by cadmad »
Kap812 wrote: Absolutely love the instrument cluster and wheel!! Was it a big job to get it coded up? Been thinking of doing the same upgrade
The wheel was real easy new swcm module needed and coded with vcds the cluster needed the immobiliser recoded along with the keys best left to someone like doc as it’s not that straight forward. Only problem with this wheel is it doesn’t light up which does annoy me lol. Might change it soon.
