My Blackberry Caddy
Caddyluv
Re: My Blackberry Caddy
Post by Caddyluv » Thu May 16, 2019 12:07 pm
Don’t bring that up.
hef355
Post by hef355 » Thu May 16, 2019 12:10 pm
Ye Stu what are your plans for that arse end
Barbel330
Post by Barbel330 » Thu May 16, 2019 12:54 pm
Well.......I’m going to blame Ryan for having to wait for a vital part which is on back order at VW even though it’s not his fault at all
In all seriousness, the new rear bumper is all ready to go on apart from 1 piece so it’s just a waiting game at the moment. It might arrive tomorrow or it might arrive in 3 months
Instagram: @y_5cuf
Barbel330
Post by Barbel330 » Mon May 20, 2019 6:33 pm
All 4 wheels ceramic coated today. I prefer to do them before tyres are fitted but I didn’t have the opportunity with this set so it took ages removing them from the van, washing, degreasing and 2 coats of Carbon Collective platinum wheels. Also roped up the coating on my calipers while the wheels were off.
Instagram: @y_5cuf
Celticrsmith
Post by Celticrsmith » Mon May 20, 2019 8:19 pm
Wow, didn’t realise how close they were to those arches! Must be a worry sometimes
Barbel330
My Blackberry Caddy
Post by Barbel330 » Mon May 20, 2019 8:40 pm
No it all clears. The rears by about 1mm but clear is clear. Obviously I don’t drive it like that, that’s just aired out :) The fitment was worked out to the nearest mm. Fronts you get some leaway and can play around with spacers and wheel offsets. It’s a balancing act between clearing the strut, clearing the calipers and clearing the arches. I’m currently running 6mm spacers on the front but could go to 8mm if I wanted. Rears are a bit more critical as you don’t have much room to play with. I have no spacers on the rear so the calculations worked out perfectly.
This was when I first tested it with these wheels. It was super close so I put a bit of tape on the rim just to see if it touched it, then slowly dropped it down mm by mm. She’s tight!!! Image
Instagram: @y_5cuf
hef355
Post by hef355 » Mon May 20, 2019 9:09 pm
Wheels are amazing Stu and transformed the van! Silver is king
Barbel330
Post by Barbel330 » Mon May 20, 2019 11:09 pm
Cheers Hef. Silver is king.......for now :)
Instagram: @y_5cuf
EngServ
Post by EngServ » Tue May 21, 2019 9:58 am
Amazing van. You’ve definitely put some hours into this :shock:
58Clowns
Post by 58Clowns » Tue May 21, 2019 11:11 am
Beautiful work!
Inspirational
1989 Golf GTI :twisted:
1989 BMW 325i :)
