My caddy build and face lift
- Caddy0802
Re: My caddy build and face lift
Nice one
- R22LRM
Quality build pal, top engineering on suspension set up
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
Have you sorted the ride height out yet Ken? You can just move the top shock mounts backwards on the threaded holes in the top plate to give you more height.
I’m still trying to sort out my very noisy watts linkage bush which knocks like mad all the time. Apparently they’re redesigning something to fix this but I’ll go as far as saying their customer service has been far from good.
Yes they are very slow. I’ve had an email today saying that the replacement watts bushes are on the way as I had the same issue.
The problem was that they were machined wrong and have too much slack in them.
Yes I have my ride hight all sorted now. I needed longer springs as the ones I had on first were too close to being cool bound.
Also got an email so hopefully this will fix it. Mine is awfully noisyKenTDI140 wrote:Yes they are very slow. I’ve had an email today saying that the replacement watts bushes are on the way as I had the same issue.
Yea mine rattles like hell.
The parcel came today. completely the wrong parts and they didn’t send me the longer drop links I was promised for the arb
Mine also turned up, I fitted mine too. The bush was a much tighter fit into the new one. The majority of the noise has gone now but it is still noisy when on an uneven surface (most of Sheffield’s roads) I think it’s the rose joints on the ends of the adjustable watts linkage arms.KenTDI140 wrote:Yea mine rattles like hell.
Might be. Ok I’ll fit what’s been sent and see what it’s like.
Most rose joints need a rubber protector to stop dirt getting in and wearing them. Also they need to be packed with grease. I noticed on these joints that there is a small spring loaded grease big point which needs a special little gun to force the grease in with.
Also on things like works mk2 escorts and 5 link set ups as I have on my mk2 rs the end that connects to the body has a poly bush and not a rose joint at each end which reduces the noise a lot
- james400
My watts link kit ive built for mine consists of mk1 escort watts link Centre and bmw adjustable arms with others bits in just in the stage of building the cage for it now
Yeah I think if they changed the rose joints for poly bushes it would be near silent.KenTDI140 wrote:Might be. Ok I’ll fit what’s been sent and see what it’s like.
Yea the works escort stuff is good quality and very strong.james400 wrote:My watts link kit ive built for mine consists of mk1 escort watts link Centre and bmw adjustable arms with others bits in just in the stage of building the cage for it now
I fitted the new diamond part of the watts linkage that they sent today. The oilite bushes were a very tight fit and it has cured the rattle from the suspension all together.
- torque777
That's good news Ken... Do you think the bushes will last?
Yea they should do but I will probably grease the pivot point every time I service it. I might even drill and fit a grease nipple later on.
Ken
I need some advice please as you’ve already done the gearbox conversion
Change gearbox with a jlu gearbox and associated driveshafts, starter and complete clutch assembly
Go turn over engine and it’s like a flat battery with starter jamming
Go to bump with a tow the gearbox seems to lock up
Remove starter and the same thing happens - as above
Seems like the flywheel assembly is “tight” to my friends who installed it (one works for Mercedes and the other Audi)
Any ideas ?
Any ideas ?
