My caddy build and face lift
KenTDI140
Re: My caddy build and face lift
Post by KenTDI140 »
Quantum shocks are all ordered now so I should have them in a couple of weeks.
Watch this space as then I can get it all fitted
torque777
Post by torque777 »
KenTDI140 wrote:Quantum shocks are all ordered now so I should have them in a couple of weeks.
Looking forward to seeing photos
KenTDI140
Post by KenTDI140 »
I will take and post picks as I’m fitting it. I’ve even managed to find a way to use shocks with 100 mum of travel
KenTDI140
Post by KenTDI140 »
Ok so the new shocks and springs arrived today ImageImage
lord-dudester
Post by lord-dudester »
Wow! They look lovely. Almost too nice to hide behind the wheels. Haha
torque777
Post by torque777 »
Very nice them
slipperjake
Post by slipperjake »
Looking good ken, How much more travel do you reckon your going to get over the standard set up?
KenTDI140
Post by KenTDI140 »
It’s not more travel over the std set up. It was more about being able to keep enough travel for the suspension to work properly. These shocks only have 100 mm of travel but that’s 30 mm more than the shocks that were being offered with the link kit.
The big problem with the std caddy rear suspension is that the shocks are at quite an inclined angle and the more you lower the caddy the worse that angle gets. Which also means that when you hit a bump and the shocks get compressed and the bigger the bump the less the shocks can do to dampen the springs.
A shock absorber works best when it’s upright and is then direct acting on the spring.
So I wanted to make sure that with my van at the ride hight I want my shocks have enough travel to not bottom out when the bump stops hit and also have enough travel so that on the rebound or when the suspension is on droop it won’t lift a rear wheel off the road which in a corner would cause the read end to loose grip.
Hope that explains it.
I’m hoping to spend a day fitting the whole kit next weekend.
Icepick1982
Post by Icepick1982 »
WOW Nice rebuild of a 2007 caddy
Got two questions
1
What did you change to fit the mk7 MFSW
2
What is the partnumber of the tray with 4 slots and switch.
Kind regards,
Icepick1982
KenTDI140
Post by KenTDI140 »
I used the different steering wheel control module and made a small alteration to the wiring harness in the wheel.
Not sure on the part no of the console section but I’m pretty sure it’s from a touran
Icepick1982
What steering wheel control module did you use and what alteration did you make? And how did you programm it.
Part no of the console section i have found that one allready.
Kind regards,
Icepick1982
KenTDI140
Post by KenTDI140 »
I used the ch module that everyone uses for the mk6 wheel and programmed it with vcds
The loom alteration was one wire for the horn
Icepick1982
Cool i allready got the ch module
And where can i find the info about what wire to alter for the horn?
Kind regards,
Icepick1982
KenTDI140
Post by KenTDI140 »
You do realise that with this mod the lights on the wheel won’t work neither will the cruise buttons
Icepick1982
No because you posted that everything worked so i assumed that de cruise buttons were also working.
Never mind then the only reason to change my mk6 wheel to mk7 were the cruise buttons.
Kind regards,
Icepick1982
