My caddy build and face lift
anoneamus
Re: My caddy build and face lift
Post by anoneamus » Mon Oct 01, 2018 10:13 am
Nice! May be worth doing a "how to", as I'd imagine there are FL conversion folks that might want to go down this route...
BTW, found this regards the ALS on HID lights:
The current VOSA MOT guide(01/01/12 onwards) states this "Vehicles equipped with High Intensity Discharge(HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system. Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given. Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch."
KenTDI140
Post by KenTDI140 » Tue Oct 02, 2018 8:50 pm
So. Basically I’m ok with head lamp washers only.
I did ask a couple of my customers as all my customers are garages and they all pretty much said if it had als fitted it must work but if I only fit washers they would not fail it on an mot.
By the way. The led cobs came today and I have managed to get the first 5 in place this evening. In the pic below u can just about make out the one I have on my finger.
They are damed small Image
anoneamus
Post by anoneamus » Wed Oct 03, 2018 11:22 am
Wow, those are tiny! Yeah, I wouldn't bother with the washers, as you probably won't get them to work without a BCM anyway, and hardly anyone here that's done the Xenon retrofit has bothered (and noone has failed MOT for that).
james400
Post by james400 » Wed Dec 19, 2018 10:03 pm
Any more update on this yet mate?
Sean1066
Post by Sean1066 » Wed Dec 19, 2018 10:48 pm
Very nice build ken
Remapped to 140, mk5 golf mfsw, Colour coded bumpers, VW Cadiz 18s, wheels, Vanstyle bumper protecter, Vanstyle rear spoiler, Vanstyle roof rails, After market fog lights. Lowered on V-Maxx, Audi A3 S Line seats on Touran bases, Audi TT air vents
KenTDI140
Post by KenTDI140 » Thu Dec 20, 2018 6:16 am
No more news on the lights as yet. One light is finnished and ready to fit but due to a faulty injector I have had to pull ou the engine again and do another complete rebuild.
Really pissed of about it as only done 2000 miles on the new engine.
What happened was an injector nozzle stuck open for a moment causing no 3 big end bearing to get crushed.
In that split second the bearing spun and took out the crank and con rod and small filings damaged the piston.
So now I have had to get another crankshaft. Gone for steel rods this time as well. Also found a mild cam shaft from a guy in Canada that knows his stuff.
Hoping to be back on the toad for Xmas.
james400
Post by james400 » Thu Dec 20, 2018 8:38 am
Sorry to hear that but no doubt it will be built bigger and better to take more power
KenTDI140
Post by KenTDI140 » Thu Dec 20, 2018 8:59 am
Well my aim is 300 bhp but still makefull boost by 1800 rpm and still keeping good drivability from 1200 rpm.
Of course the steel rods will be lighter so they will help with pick up. Apart from that the only real difference is going to be the cam which has .5mm higher lift but no more total valve duration. And the cam has slightly more lift on the injector lobe.
KenTDI140
Post by KenTDI140 » Sun Jan 06, 2019 6:31 pm
Van is now back on the road and half way into the running in of the engine.
I managed to find a high lift cam from franks tdi’s llc in Canada.
I didn’t want a full race cam like dark side and so many other places offer as I like drivability and low end torque.
jamie8gti
Post by jamie8gti » Mon Jan 07, 2019 11:42 am
wow what a build! she's come a long way! front bumpers both look great! mk2 even more so. :D
