My caddy build and face lift
KenTDI140
Re: My caddy build and face lift
Post by KenTDI140 » Fri Mar 22, 2019 8:36 am
I have found a way to make it all work but it means stripping the lights down. Doing away with the led set up and building my own led lights and using traditional wiring methods. One light is finished and works fine but I just have not had time to do the other one yet.
anoneamus
Post by anoneamus » Fri Mar 22, 2019 10:23 am
Pirelli901R wrote:
Thu Mar 21, 2019 7:46 pm
I'm trying the same thing, I have the same problem, had new bcm 5K0937087 but still no high beam and leds.
If you have a BCM you can do the proper retrofit. KenTDI140 had to do major workarounds as he is using CECM which doesn't have support for ALS. Your description implies you have either not fitted ALS, or it is not wired/coded correctly. Here is a guide for the retrofit:
https://caddy2k.com/forum/viewtopic.php?f=22&t=25064
KenTDI140
Post by KenTDI140 » Fri Mar 22, 2019 10:30 am
The retro fit was not possible on my van as it’s an 07. I would have had to totally fit an 11 plate on loom which is more than I was prepared to do.
I have not fitted als
Pirelli901R
Post by Pirelli901R » Fri Mar 22, 2019 9:54 pm
I can't open topic because I still don't have permission. My Caddy i 2011, I wonder is it big diference in 087A wich I have and 087AC wich I found someone in this forum had proper retrofit?
anoneamus
Post by anoneamus » Sun Mar 24, 2019 5:34 am
Contribute. Make a topic about your van. This is a give and take forum, so if you want to take you must give. In any case, as long as your BCM is 086 or later (I really don't think it makes a difference which letters follow), it has the necessary support for BiXenon. If your van is 2011 you must have replaced BCM, as 087 was only factory fitted after 2014 AFAIK.
Azz03
Post by Azz03 » Mon Jun 10, 2019 2:07 pm
Wow is all I can say ken you’ve got an incredible amount of patience and skill love the motivation you have even after trashing the front end you’ve bounced back like it’s nothing top notch mate just a quick one you’ve clearly got a lot of knowledge on engines and how they work lol I’m wondering do you know much about the engine conversions?
Thanks in advance.
KenTDI140
Post by KenTDI140 » Mon Jun 10, 2019 2:10 pm
The conversion is the easy bit it’s getting the ecu to work that’s the hard bit and wiring changes.
Although mine is heavily modified it’s still essentially the std 1900 engine so I’m still on my original ecu.
Azz03
Post by Azz03 » Mon Jun 10, 2019 2:12 pm
My friend/mechanic was part way through it but sadly passed away so I’m left with an unfinished engine. Was just wondering if I could pm you as I’m stuck with a few things. Thanks for the reply.
KenTDI140
Post by KenTDI140 » Mon Jun 10, 2019 2:14 pm
I’ll try to help if I can
Sean1066
Post by Sean1066 » Mon Jun 10, 2019 3:59 pm
Hi ken
How did you get your mk7 Golf steering wheel to work?
As I have one but can’t get it to work?
My build thread
KenTDI140
Post by KenTDI140 » Mon Jun 10, 2019 7:23 pm
If I remember right I moved one wire so that the horn worked the lights don’t work but all the main controls do
