Natural grey caddy build
slipperjake
Re: Natural grey caddy build
Post by slipperjake »
18z caliper are direct bolt on. Just need the correct bolts and some discs of merecedes ml 350mm you will also need to change hoses so a good time to upgrade to braided hoses.
slipperjake
Been busy on the van lately, in the process of fabricating rear watts link rear brake brackets.
More pics to follow when all is complete
slipperjake
Also got darkside s3 type intercooler to go on ready for more ponies
slipperjake
Watts linkage is now all painted and finished. Also poly bushed leaf springs and shackle bushes.
This has made a huge difference the the handling axle is now solid.
Barbel330
Post by Barbel330 »
Serious business. Nice work! :)
Instagram: @y_5cuf
slipperjake
Yeah cheers, been busy few weeks!
kox
Post by kox »
Hi.love the car.Can you tell me whit this brakes on the front which is the minimum rim size you can fit? Thanks
slipperjake
I’d say minimum 18” wheels.
the long one
Post by the long one »
Where did you get the watts linkage ? Like idea but unsure what it does - anything to stop that axle from misbehaving has got be to be good :D :D :D
slipperjake
We custom made it all ourselves.
It basically limits the side to side movement of the axle.
james400
Post by james400 »
slipperjake wrote:We custom made it all ourselves.
Would you build the kit to sell?
slipperjake
No sorry I wouldn’t have time or be worth while doing. My original plan was to turret the rear end and do away with the axle all together and have it fully Independant, but funds did not allow this
slipperjake
Converted the van to studs, should make taking wheels on and off with spacers easier!
slipperjake
Also looking at tubular front control arms, with a raised tubular subframe. I think this would aid front end traction a lot with hard cornering and braking.
the long one
What about the super pro alloy arms ? Mind you that would mean a new sub frame ?
