Natural grey caddy build
slipperjake
Re: Natural grey caddy build
Post by slipperjake » Fri Nov 10, 2017 10:41 pm
I think tubular t45 would be far stronger and more adjustable as this would be on Rose joints. I would make a tubular subframe maybe slightly raised higher than the stock this would allow the arms to sit at parallel or above to the ground this will improve handling a lot.
torque777
Post by torque777 » Fri Nov 10, 2017 11:04 pm
Great work, especially like the watts linkage
the long one
Post by the long one » Sat Nov 11, 2017 8:01 am
Lots of great work going on here sometime I wish that I went for swb instead of a lwb it seems they’re easier to mod
Not as much weight issues as maxi on the rear
B3NNB
Post by B3NNB » Tue Nov 14, 2017 10:38 pm
Have you got a contact number for Bobby Singh??
slipperjake
Post by slipperjake » Tue Nov 14, 2017 10:50 pm
Just pm you
B3NNB
Post by B3NNB » Wed Nov 15, 2017 6:43 am
slipperjake wrote:Just pm you
Says I’m not authorised to read PMs
Send me a text please mate 07480418556
slipperjake
Post by slipperjake » Wed Dec 27, 2017 7:04 pm
Just gave her fresh oil and filter. Been doing it every 5k.
Also noticed the guard I fitted has been doing its job! ImageDefinitely worth buying if lowered.
Maxi4life
Post by Maxi4life » Wed Dec 27, 2017 10:50 pm
This is looking like a top build, good work!
JoeyLPC
Post by JoeyLPC » Wed Dec 27, 2017 11:11 pm
Smart looking caddy!
Where did you get the guard from?
slipperjake
Post by slipperjake » Wed Dec 27, 2017 11:29 pm
The guard is from reflex, well worth the money!
Mmoccia
Post by Mmoccia » Thu Dec 28, 2017 10:42 am
slipperjake wrote:Been busy on the van lately, in the process of fabricating rear watts link rear brake brackets.
More pics to follow when all is complete
Like the purple calipers, what car did you get this brake set-up from?
slipperjake
Post by slipperjake » Thu Dec 28, 2017 10:51 am
Their Bembo calipers found on Porsche Cayenne, Audi Q7, vw Touareg. The rear hand brake calliper is a Brembo Ferrari calliper.
Mmoccia
Post by Mmoccia » Thu Dec 28, 2017 10:52 am
slipperjake wrote:Their Bembo calipers found on Porsche Cayenne, Audi Q7, vw Touareg. The rear hand brake calliper is a Brembo Ferrari calliper.
Thanks for the quick reply. Were they straight bolt on or did you have to get brackets made up?
slipperjake
Post by slipperjake » Thu Dec 28, 2017 11:32 am
Fronts directly bolt up onto the hub, you will need new brake lines and different discs, I think I had the discs of a ml350.
The rears are a lot of work probably took me 3 days! Because I had to make up custom brackets. You will have to use longer brake lines and had to get longer hand brake cables made up.
Their well worth the upgrade if your looking for ultimate stopping power!
the long one
Post by the long one » Sun Dec 31, 2017 5:46 pm
What bushes did you use on the rear end - I was looking to fit powerflex black to mine (a maxi) on the rear think the maxi is a bit more stable when lowered but could just be me
Who is online
Users browsing this forum: No registered users and 1 guest
