SRS Automotive 300+bhp BKD #Racevan - Ex Darkside Developments
Re: SRS Automotive 300+bhp BKD #Racevan - Ex Darkside Developments
I have been following this on Edition
Great van
Great van
- torque777
Can the bushes be pushed out? I will be doing this on the drive
Re: RE: Re: SRS Automotive 300+bhp BKD #Racevan - Ex Darkside Developments
I'm also interested in the answer to thistorque777 wrote:Can the bushes be pushed out? I will be doing this on the drive
Sent from my HTC One_M8 using Tapatalk
I doubt it without heating them up some how.torque777 wrote:Can the bushes be pushed out? I will be doing this on the drive
We didn't completely burn them out, just got them warm then knocked them out with the hammer.
Maybe if you used a heat gun it might work?
- torque777
Thanks, I do have some gaz I use for soldering so maybe that would do, can you tell me if the chassis bush originally is a two piece? Looking on parts diagrams it looks it
Looks like there is a cup tool to press this bush out.
It is one piece, even though the ETKA diagram makes it look like a two piece.
Here's the removal instructions from ElsaWIN.
- torque777
Sorry only just seen this, looks like Doc sorted the job out anyway.torque777 wrote:Thanks, I do have some gaz I use for soldering so maybe that would do, can you tell me if the chassis bush originally is a two piece? Looking on parts diagrams it looks it
Hi,
Really love the look of your Caddy looks really good with new graphics.
The Compomotive alloys look great on it what offset where these alloys. Im going for the Rota D154 which are very similar and are 8.5x18 offset 45 so hopefully should fit flush with arches.
The wheels on my van are 8x18 ET45, I have TT front wide track on it though so they sit further out on than on standard Caddy suspension.Autodevelopments wrote:Hi,
One of the rears sits really nice and the other needs a 10mm spacer due to the offset axle for the fuel filler neck.
I always use this before buying any wheels.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator" onclick="window.open(this.href);return false;
- hedge
Awesome work, really good to see someone pushing the performance/handling side of the caddy forward
Much more to come, watch this spacehedge wrote:Awesome work, really good to see someone pushing the performance/handling side of the caddy forward
That is some real power, Which Engine, Turbo and injectors are you running ?
I am pretty happy with my remapped stock CAYE engine, Though I only use it as my daily driver so I don´t really need any extreme power, maybe I will tweak some more later.... I have only had my caddy for a few days now
Hi,pktuning wrote:That is some real power, Which Engine, Turbo and injectors are you running ?
This is used as a daily / parts collection van. I took it on a track day as my track car wasn't ready but doubt it will go on track again.
The full spec is here:
http://www.darksidedevelopments.co.uk/c ... v-tdi-bkd/" onclick="window.open(this.href);return false;
I love that CNC machined billet collector, Looks like a really nice build!Mayor West wrote:Hi,
http://www.darksidedevelopments.co.uk/c ... v-tdi-bkd/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Previously I have done a lot of custom remaps with mechanically altered petrol engines, but I have not done anything like that with a diesel......
Now you have given me bad ideas
