My new Caddy 4 build thread
stan-the-man
Re: My new Caddy 4 build thread
Post by stan-the-man » Tue Feb 27, 2018 1:08 pm
Seat heating as the heated wheel works based on resistance. You will need to run a wire from drivers side seat plug and ground at the column.
You need to get mqb slipring from a car with heated wheel as it will have additional connection on spinning section for it.
Pic above is mine already done but you can see the extra plug connection on the lower left. That’s where the wheel plugs in.
Basically once you take apart the MQB slipring you will be using the front spinning plate + the surround cover + internal tape that’s inside it and install it into your slipring.
I will probably make a new thread about it with some pics for people to understand how I done itImage
Sportvan
Post by Sportvan » Wed Feb 28, 2018 7:11 am
Awesome job! Wouldn’t mind a heated wheel.
Caddy Highline 150tdi Dsg etc etc
LeeH
Post by LeeH » Wed Feb 28, 2018 11:29 am
Heated wheels are very handy in the snow...
Ddraeg
Post by Ddraeg » Thu Mar 01, 2018 8:30 am
I keep thinking about this mod every morning when I try to peel my frozen hands from the steering wheel.
Tomkin
Post by Tomkin » Sun Apr 08, 2018 11:18 pm
Hi, my names Tom, this I my first post was wondering if you could help I have a 2017 150 caddy and wan to fit acc and paddles I've got cruise as standard and the radar at the front and emergency braking so have ordered a 5ta steering wheel but could you give me the coding for channel 13 acc please, also I've enabled folding mirrors but would like to reduce the delay, I have vcds and vagcan pro thanks..
Regards tom.
stan-the-man
Post by stan-the-man » Mon Apr 09, 2018 8:32 am
Hi Tom I’ll post the coding later on for ya. I think you’ll need to get it calibrated as well. Not sure if it’s that straight forward to fit the ACC as I think it could be part of component protection so requires dealer tools
Tomkin
Post by Tomkin » Mon Apr 09, 2018 8:36 pm
Thanks very much for the reply, was hoping vagcan pro could help me but I could ask the dealer to do it then for me. Sorry but on the folding mirrors is that straight forward to adjust the delay when I press the button it takes a few seconds to retract once I press lock button thanks.
Tom.
stan-the-man
Post by stan-the-man » Mon Apr 09, 2018 9:37 pm
My ACC coding is:
00001000FE0339
Regarding the delay...
I’m not gonna be held responsible if something goes wrong
09 central electrics
Security access
Login
Engineering mode
Up/download
Navigate to 1120,1121,1122
where first two numbers should be “14”
So 14XX 14XX 14XX
Change all three 14s to:
01 or 02 or 03 which stands for 0.1sec or 0.2 sec or 0.3 sec and so on.
01 is useless and possibly 02 might be too as this will also affect your windows opening closing so might make your windows go down a bit once you unlock the car.
Hope that helps!
Tomkin
Post by Tomkin » Mon Apr 09, 2018 10:16 pm
Absolutely brilliant, awesome many thanks.
Kind regards tom.
Tomkin
Post by Tomkin » Tue Apr 17, 2018 10:01 pm
Hi Stan sorry to be a pain pal, steering wheel fitted to do acc retro fit but when I come to check the coding I found no coding table for engine ecu so struggling to code it this is my coding and just wondered if it differs from yours thanks. 011D00120445150090000 only I keep getting error 17149 check coding of ecus on power train data bus.
Kind regards tom.
Liam
Post by Liam » Sun Apr 29, 2018 6:15 am
what a van
shes a credit to you stan
Remapped by Joe Power at TDR.ie
Passat Cc leather interior
18” Vancouver Reps
Eibach pro lowering kit
the list goes on 😝
http://www.tdr.ie
pecik91
Post by pecik91 » Sun Apr 29, 2018 10:54 am
Great build, love it!
peggan
Post by peggan » Sat May 05, 2018 8:29 pm
Awesome build!
Where can i find this camera? Looks perfect!
Do you have a part number? :)
stan-the-man wrote:
Sun Feb 25, 2018 3:07 pm
My Ampire reverse camera failed few weeks ago.
stan-the-man
Post by stan-the-man » Sun May 06, 2018 9:39 am
Thanks lads!
The camera is this one:
https://www.ebay.co.uk/itm/232612589200
The footage quality is spot on in my opinion. ImageImage
peggan
Post by peggan » Mon May 07, 2018 8:49 pm
Thanks lads!
The picture look perfect! Thanks for the link, I will order the same one :)
What kind of cable did run up to the stereo?
