My build project.
Ianbcaddy
My build project.
Post by Ianbcaddy »
Had the caddy a few months now and been collecting bit and pieces, now starting to fit them. This is a long term project, starting from the inside. I have ply lined most of it, arches still to do. Started carpeting with the headlining and sliding door done. Tweeters fitted in the b post trims. More to follow.ImageImageImageImageImage
Ianbcaddy
Re: My build project.
Post by Ianbcaddy »
More work done this weekend. Dab aerial fitted and speaker pods sorted, they will go behind the seats.ImageImageImage
shanky887614
Re: RE: My build project.
Post by shanky887614 »
nice, is that the halma aerial?
Reason: remove unnecessary quote
Ianbcaddy
Post by Ianbcaddy »
shanky887614 wrote: nice, is that the halma aerial?
Yes, got it off amazon.
shanky887614
Re: RE: Re: My build project.
Ianbcaddy wrote: Yes, got it off amazon.
nice, im thinking of swapping mine for one with gps
Benz0187
Post by Benz0187 »
Behind or under the seats?
Skickat från min iPhone med Tapatalk
________________________________________________________________Benz0187___
Ianbcaddy
Post by Ianbcaddy »
They are going in the space under the floor behind the seats, amp and sub going under the seats. More pictures when done.
SimonR
Post by SimonR »
I like the looks of that aerial.... I was thinking of going for a gps / dab combined .... like the skoda yeti maybe
Ianbcaddy
Post by Ianbcaddy »
More work done, speaker pods, under seat sub and amp all fitted. The wiring for them sorted as well. Fitted Touran carpets and some of the consol.ImageImage
Ianbcaddy
Post by Ianbcaddy »
Reversing camera, Touran seats and console fitted. Was a right pain getting the wires through the grommet into the rear door!ImageImage
KenTDI140
Post by KenTDI140 »
Nice job so far keep. Going
Harry2k
Post by Harry2k »
Nice work so far. Does the reverse camera go to one of them LCD display on the rear view mirror?
H
Ianbcaddy
Post by Ianbcaddy »
It will go to the head unit once I fit it. Doing a Touran dash conversion so not fitted it yet.
Grunt
Post by Grunt »
Hi, where did you source the reversing cam from? Cheers
Ianbcaddy
Post by Ianbcaddy »
From eBay. Called autotunez. Fits ok although I had to use slightly longer screws as it's thicker than the number plate light. It has a built in led number plate light which needs a resistor or it brings up warning light. Haven't tested camera yet as I haven't fitted head unit.
